426 Hemi cross ram question #2293997
04/25/17 05:43 PM
04/25/17 05:43 PM
cheshire, ct
davesmopars Offline OP
cheshire, ct
I am putting a stoked Hemi 604 pump gas in my 68 Barracuda not really a race car. Once a year track car, Mostly just for enjoyment.
Cross ram I have is an original 68 one or are the mopar performance one better for what I am going to with the car. Or do you guys recommend something else
thanks for any help
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
Re: 426 Hemi cross ram question [Re: davesmopars] #2294006
04/25/17 05:56 PM
04/25/17 05:56 PM
an8sec70cuda Offline
The Mopar Performance crossrams are supposed to be much larger internally than the factory crossrams, which is better for your big stroker.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 426 Hemi cross ram question [Re: an8sec70cuda] #2294052
04/25/17 07:49 PM
04/25/17 07:49 PM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
I have both an original and a Mopar Performance cross-ram. The
Mopar has bigger runners needed for the big cubic inch motors. It would cut big power using the original. The port walls on the original are too thin to open the ports.
Re: 426 Hemi cross ram question [Re: davesmopars] #2294134
04/25/17 10:05 PM
04/25/17 10:05 PM
I've never seen or heard of a original Hemi cross ram intake and carbs. run as bad as the newer Mopar two piece cross ram do, the new ones are turds in my book down
The old cast one piece aluminum ones are a lot lighter weight and fit way better on the motors also without having to massage the external sides for valve cover clearances work
Re: 426 Hemi cross ram question [Re: davesmopars] #2294356
04/26/17 08:51 AM
04/26/17 08:51 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
The new X-ram manifold can be modified much easier than the original.With the removable top plates the interconnection can be easily enlarged as well as the entrance of the port runners.The thick walls can be opened up at the gasket areas and the runner transisions can be blended.A lot of weight can be removed from this manifold as it is quite heavy.Done correctly good HP and torque can be achieved.The sad part is a good single plane high volume manifoild can perform as well and even better.
Re: 426 Hemi cross ram question [Re: davesmopars] #2294446
04/26/17 12:28 PM
04/26/17 12:28 PM
Took this from the KB block post. From Ray Barton...
Ray Barton Racing Engines has a magnesium CrossRam intake on our website (see link below) that can support over 1000HP. It doesn't make anymore peak HP than a big, open plenum, single four barrel with a big carb. However, it makes a ton more low and midrange torque which is beneficial for heavy or automatic transmission vehicles. Also the RBRE or the newer Mopar manifold can be real animals with good drivability if the carbs are reworked properly. All of the newer Holleys for these manifolds are no good out of the box but can be corrected. -- Ray
http://raybarton.com/parts/index.php/par...ossram-manifold
CHIP
Re: 426 Hemi cross ram question [Re: an8sec70cuda] #2294482
04/26/17 01:29 PM
04/26/17 01:29 PM
PA
RBRE Offline
RBRE  Offline
PA
Thanks an8sec70cuda. Posted this crossram response to wrong thread.
Re: 426 Hemi cross ram question [Re: RBRE] #2294564
04/26/17 04:45 PM
04/26/17 04:45 PM
cheshire, ct
cheshire, ct
Thanks for all the input. This is the engine in my buddies Dart That was going in to his 68 Barracuda But I found his original engine, now no need for this Hemi so I am buying it from him. This is a learning curve for me. I bin a 440 guy.
mcodecuda@yahoo.com
Re: 426 Hemi cross ram question [Re: davesmopars] #2294731
04/26/17 11:03 PM
04/26/17 11:03 PM
Dat be one of the gooder kind of OEM Crossram up bow
Hopefully the carbs.are to luck
Re: 426 Hemi cross ram question [Re: davesmopars] #2294906
04/27/17 10:16 AM
04/27/17 10:16 AM
If you'd rather go fast, get one of these...
CHIP
