426 Hemi cross ram question
#2293997
04/25/17 05:43 PM
04/25/17 05:43 PM
Posts: 3,393 cheshire, ct
davesmopars
cheshire, ct
I am putting a stoked Hemi 604 pump gas in my 68 Barracuda not really a race car. Once a year track car, Mostly just for enjoyment.
Cross ram I have is an original 68 one or are the mopar performance one better for what I am going to with the car. Or do you guys recommend something else thanks for any help
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
Re: 426 Hemi cross ram question
[Re: davesmopars]
#2294006
04/25/17 05:56 PM
04/25/17 05:56 PM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
The Mopar Performance crossrams are supposed to be much larger internally than the factory crossrams, which is better for your big stroker.
[Re: davesmopars]
#2294446
04/26/17 12:28 PM
04/26/17 12:28 PM
an8sec70cuda
Took this from the KB block post. From Ray Barton... Ray Barton Racing Engines has a magnesium CrossRam intake on our website (see link below) that can support over 1000HP. It doesn't make anymore peak HP than a big, open plenum, single four barrel with a big carb. However, it makes a ton more low and midrange torque which is beneficial for heavy or automatic transmission vehicles. Also the RBRE or the newer Mopar manifold can be real animals with good drivability if the carbs are reworked properly. All of the newer Holleys for these manifolds are no good out of the box but can be corrected. -- Ray http://raybarton.com/parts/index.php/par...ossram-manifold
[Re: an8sec70cuda]
#2294482
04/26/17 01:29 PM
04/26/17 01:29 PM
Posts: 22 PA
RBRE
PA
Thanks an8sec70cuda. Posted this crossram response to wrong thread. Ray Barton Racing Engines has a magnesium CrossRam intake on our website (see link below) that can support over 1000HP. It doesn't make anymore peak HP than a big, open plenum, single four barrel with a big carb. However, it makes a ton more low and midrange torque which is beneficial for heavy or automatic transmission vehicles. Also the RBRE or the newer Mopar manifold can be real animals with good drivability if the carbs are reworked properly. All of the newer Holleys for these manifolds are no good out of the box but can be corrected. -- Ray http://raybarton.com/parts/index.php/par...ossram-manifold
[Re: RBRE]
#2294564
04/26/17 04:45 PM
04/26/17 04:45 PM
davesmopars
cheshire, ct
Thanks for all the input. This is the engine in my buddies Dart That was going in to his 68 Barracuda But I found his original engine, now no need for this Hemi so I am buying it from him. This is a learning curve for me. I bin a 440 guy.
[Re: davesmopars]
#2294906
04/27/17 10:16 AM
04/27/17 10:16 AM
an8sec70cuda
If you'd rather go fast, get one of these...
