OE '66 Hemi trans cooler: large enough for gears & stall? #2293681
04/25/17 07:14 AM
04/25/17 07:14 AM
808CUDA Offline OP
808CUDA  Offline OP
Thoughts on the factory OE auxiliary trans cooler that came with factory 426 Hemi cars.
Will it provide sufficient cooling for a mild street Hemi car with a reverse manual valve body, ~3,000 stall and 3.91 gears with 28" tall tires?
Thanks in advance for any input.
Any really good aftermarket trans cooler with threaded fittings suggested if not sufficient?
Re: OE '66 Hemi trans cooler: large enough for gears & stall? [Re: 808CUDA] #2293770
04/25/17 11:56 AM
04/25/17 11:56 AM
I would want more than that. As we know heat is the killer & I'm sure you have alot of dough tied up in the trans as well. there was something posted way back about a "stacked plate" type being superior, You might Google it.
Re: OE '66 Hemi trans cooler: large enough for gears & stall? [Re: 808CUDA] #2293817
04/25/17 01:27 PM
04/25/17 01:27 PM
Chicago
PurpleBeeper Offline
Chicago
The "stacked plate" coolers (more of a semi-truck product than a car product) are more durable for sure, but I'm not sure if they cool any better than the regular "tube & fin" type.
In my opinion, a stock-style transmission cooler is nowhere near enough cooling for your stall/gears. I suggest you at least consider one of those setups that comes with its own cooling fan(s). If you keep the fluid cool, your transmission will lead a long, happy life.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: OE '66 Hemi trans cooler: large enough for gears & stall? [Re: 808CUDA] #2294295
04/26/17 02:02 AM
04/26/17 02:02 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
you can have too small of a trans cooler but you can not have too large of a cooler !
stock hemi had 2800 stall converter , you might be fine with it .
Re: OE '66 Hemi trans cooler: large enough for gears & stall? [Re: 808CUDA] #2294305
04/26/17 02:41 AM
04/26/17 02:41 AM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
With your set up it should be fine. I've ran a 12 1/2 cr Hemi with 4.30 gears on the street using the factory cooler.
Re: OE '66 Hemi trans cooler: large enough for gears & stall? [Re: 808CUDA] #2294318
04/26/17 03:52 AM
04/26/17 03:52 AM
A727Tflite Offline
A727Tflite  Offline
If you have an IR gun, hit the trans pan after several different drives and see what temps you are getting to. This is what the trans sees. We all have our opinions but you can't argue with real world data. Then of course you have to decide what is too hot for temperature. confused
Re: OE '66 Hemi trans cooler: large enough for gears & stall? [Re: 808CUDA] #2294332
04/26/17 05:45 AM
04/26/17 05:45 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
The factory cooler should be enough, but if you want more some 70s Dodge trucks had external oil coolers that bolted right in.
Re: OE '66 Hemi trans cooler: large enough for gears & stall? [Re: 808CUDA] #2294859
04/27/17 04:57 AM
04/27/17 04:57 AM
808CUDA Offline OP
808CUDA  Offline OP
Thanks everyone for the input! Much appreciated. I'll proceed with stock and update with my findings.
