Re: hemi head what do I have???
[Re: His and Her 69's]
#930853
02/17/11 06:17 AM
02/17/11 06:17 AM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
LONG OBSOLETE. nearly all were ported for blower use. under no circumstances consider using them until you have them flowed. blower heads will turn an otherwise potential terror into a pig
Castinng Numbers heads 2468016 1964 426 (Cast K) Hemi 2488596 1964 426 (Early Production or Prototype Race) Hemi Note - Square Valve Covers 2531110 -M 1965 426 (Alum "Alcoa") (direct connection Hemi heads) 2531110 -M2 new Edelbrock MP Hemi heads 2531695 1965 426 (Alum "Alcoa" Rev B) 2531718 426 (A-148) Hemi 2780559 1966-1971 426 (Cast Iron) Hemi 2945270 426 (Cast Iron D3) Hemi 3512015X 426 (D4) Hemi 3614433 426 (Aluminum) Hemi Intake 2468045 1964 426 Hemi 2x4 Aluminum Cross Ram (Super Stock) 2536900 1965-1968 426 Hemi 2x4 Magnesium Cross Ram (A990) 2780543 1966-1971 426 Hemi 2x4 exhaust 2780508 426 Hemi Cast Iron (Passenger) 3418453 426 Hemi Cast Iron (Driver Side)
home of the Sox and Martin Hemi Duster
#930854
02/17/11 12:52 PM
02/17/11 12:52 PM
Posts: 642 New Jersey
Craig
New Jersey
Those are the heads I have. If they haven't been excessively ported, they should be good. Mine have been ported a little and the intake ports are 2.06x1.85, maybe that can give you an idea if yours are usable. I'm sorry I don't have ex port dimensions handy.
Edit: mine are Rev D.
67 Dart, 426 Hemi, 9.23/145mph, 3400lbs, footbraked, owned since 1982
[Re: moderncylinder]
#930857
02/18/11 02:43 PM
02/18/11 02:43 PM
Posts: 3,505 DFW
mr_340
DFW
Weren't the Ross foundry aluminum heads basically an aluminum version of the 559 head, but with the dual plugs machined? If they aren't ported and flow about the same as an unported 559, that would seem to be right. I'm sure Jeff can port them with his 559 program(s) and boost that by 100 cfm.
Floyd Lippencott IV
#930858
02/18/11 10:26 PM
02/18/11 10:26 PM
Posts: 1,634 Petersburg, Va
Darrell
Petersburg, Va
i just flowed a set of stock 559 iron heads and they flowed 325 at .500 lift,, if your flow 331,, thats not good
What did they do after .500? ![](/ubbthreads/images/graemlins/wave.gif)
#930860
02/19/11 12:10 AM
02/19/11 12:10 AM
fast68plymouth
So. Burlington, Vt.
i have a set of low mile OE 559 heads in the shop. with the factory valve and valve job. on a 4.250 bore......as i recall, they only flowed like 285 @ .500 lift.
i had another set in the shop not too long ago, fresh radius type valve job and bowl blend from Barton, Manley valves......i think they were in the 330's.
i'll check my notes to verify the numbers.
#930862
02/21/11 11:07 AM
02/21/11 11:07 AM
Craig
New Jersey
I have been told the only disadvantage with these heads is the aluminum is softer than newer castings. I did have some head gasket sealing issues. For use with a blower I would recommend being especially careful with sealing (decks clean and flat, full torque on good new fasteners). Here is a link to the tech archives with the flow numbers for mine: http://www.moparts.org/Tech/Archive/bb/16.html
#2292715
04/23/17 02:01 PM
04/23/17 02:01 PM
Posts: 2,678 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
The 433 is called the replacement head, aka twin plug head. This was the first aluminum head after the 65 heads. The ports had to be stock for use on 65 cars. Dual plug provisions for pro stock. This head was the everything head for Hemis for a long time, SS, top fuel, boats, pro stock, anybody that wanted to go fast. You buy them and send them to your favorite head porter, Mullins, Diamond, whatever. They are good heads and you can still send them out and have them ported and they will be anything you want. The problem is Edelbrock heads are the deal of the century. (They flow like ported 433 heads.) Edelbrock heads are the same price as ported 433 heads in 1975. Think about that. It's a good time to be a Hemi man.
2011 Drag Pak Challenger
