hemi head what do I have??? #930852
02/17/11 05:40 AM
02/17/11 05:40 AM
Oh
His and Her 69's Offline OP
Oh
I have an aluminum hemi head and I am not sure if it's a good head or average head or ???
Any help would be Appreciated on identifying them.
It is a Dual Plug, alum Hemi head, it has a number on it 3614433
and under that it has rev ? , I can't tell the last number but I am thinking it means a revision done on the head from the original design.
Also it has a DXSE 12 towards the lower valve cover rail between the valve and the rail. All the numbers are casted into the head.
All the port openings are square or retangle shaped.
Thanks For any info. I have a couple photos that I need to transfere from my phone yet.
Thanks David
Re: hemi head what do I have??? [Re: His and Her 69's] #930853
02/17/11 06:17 AM
02/17/11 06:17 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
LONG OBSOLETE. nearly all were ported for blower use. under no circumstances consider using them until you have them flowed. blower heads will turn an otherwise potential terror into a pig
Castinng Numbers
heads
2468016 1964 426 (Cast K) Hemi
2488596 1964 426 (Early Production or Prototype Race) Hemi Note - Square Valve Covers
2531110 -M 1965 426 (Alum "Alcoa") (direct connection Hemi heads)
2531110 -M2 new Edelbrock MP Hemi heads
2531695 1965 426 (Alum "Alcoa" Rev B)
2531718 426 (A-148) Hemi
2780559 1966-1971 426 (Cast Iron) Hemi
2945270 426 (Cast Iron D3) Hemi
3512015X 426 (D4) Hemi
3614433 426 (Aluminum) Hemi
Intake
2468045 1964 426 Hemi 2x4 Aluminum Cross Ram (Super Stock)
2536900 1965-1968 426 Hemi 2x4 Magnesium Cross Ram (A990)
2780543 1966-1971 426 Hemi 2x4
exhaust
2780508 426 Hemi Cast Iron (Passenger)
3418453 426 Hemi Cast Iron (Driver Side)
home of the
Sox and Martin Hemi Duster
Re: hemi head what do I have??? [Re: His and Her 69's] #930854
02/17/11 12:52 PM
02/17/11 12:52 PM
New Jersey
Craig Offline
Craig  Offline
New Jersey
Those are the heads I have. If they haven't been excessively ported, they should be good. Mine have been ported a little and the intake ports are 2.06x1.85, maybe that can give you an idea if yours are usable. I'm sorry I don't have ex port dimensions handy.
Edit: mine are Rev D.
67 Dart, 426 Hemi, 9.23/145mph, 3400lbs, footbraked, owned since 1982
Re: hemi head what do I have??? [Re: Craig] #930855
02/18/11 03:41 AM
02/18/11 03:41 AM
Oh
Oh
So my hemi heads #3614433 are just alum hemi heads and nothing special??
I plan on using a blower on them with an old mopar alum hemi block that I have.
Also I would like to use both plugs and get a dual dist.
I did have the heads flowed and they flow 331 on the intake side. I don't have the paper so I don't remember at what lift it was at max.
We got a tunnelram with the motor setup for 2 domi carbs but not sure if I will use it. Probably if I run out of money to soon I will. (with the hemi in it I am sure I will run out) Ha ha.
Sorry the photos are to big for here. I will see about downsizing them.
Thanks for the info.
David
Re: hemi head what do I have??? [Re: His and Her 69's] #930856
02/18/11 11:46 AM
02/18/11 11:46 AM
detroit area
moderncylinder Offline
detroit area
i just flowed a set of stock 559 iron heads and they flowed 325 at .500 lift,, if your flow 331,, thats not good
Re: hemi head what do I have??? [Re: moderncylinder] #930857
02/18/11 02:43 PM
02/18/11 02:43 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Weren't the Ross foundry aluminum heads basically an aluminum version of the 559 head, but with the dual plugs machined? If they aren't ported and flow about the same as an unported 559, that would seem to be right. I'm sure Jeff can port them with his 559 program(s) and boost that by 100 cfm.
Floyd Lippencott IV
Re: hemi head what do I have??? [Re: moderncylinder] #930858
02/18/11 10:26 PM
02/18/11 10:26 PM
Petersburg, Va
Darrell Offline
Darrell  Offline
Petersburg, Va
What did they do after .500?
Re: hemi head what do I have??? [Re: Darrell] #930859
02/18/11 10:30 PM
02/18/11 10:30 PM
detroit area
detroit area
they had a good valve job and a backcut valve in them,,, aft .500 they stopped and flowed the same basicaly
Re: hemi head what do I have??? [Re: moderncylinder] #930860
02/19/11 12:10 AM
02/19/11 12:10 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
i have a set of low mile OE 559 heads in the shop.
with the factory valve and valve job.
on a 4.250 bore......as i recall, they only flowed like 285 @ .500 lift.
i had another set in the shop not too long ago, fresh radius type valve job and bowl blend from Barton, Manley valves......i think they were in the 330's.
i'll check my notes to verify the numbers.
Re: hemi head what do I have??? [Re: fast68plymouth] #930861
02/21/11 04:57 AM
02/21/11 04:57 AM
Oh
Oh
I will see about measuring the ports and compare them to the ones you guys have. I will also look for my flow sheet on them.
My engine guy said with a blower it won't matter what they flow.
It will be forced thru anyways.
Thanks Guys for the info.
David
Re: hemi head what do I have??? [Re: His and Her 69's] #930862
02/21/11 11:07 AM
02/21/11 11:07 AM
New Jersey
Craig Offline
Craig  Offline
New Jersey
I have been told the only disadvantage with these heads is the aluminum is softer than newer castings. I did have some head gasket sealing issues. For use with a blower I would recommend being especially careful with sealing (decks clean and flat, full torque on good new fasteners). Here is a link to the tech archives with the flow numbers for mine: http://www.moparts.org/Tech/Archive/bb/16.html
Re: hemi head what do I have??? [Re: Craig] #930863
02/22/11 05:36 AM
02/22/11 05:36 AM
Oh
Oh
I found my flow sheet for my 3614433 heads. I don't know what has been done on them as we got them on a trade deal.
Here are the flow #s,
lift Int exh
.200 148.9 133.6
.250 187.9 152.7
.300 220.9 174.4
.350 255.1 189.4
.400 276.9 199.8
.450 296.1 206.4
.500 311.0 210.0
.550 323.0 210.7
.600 331.5 211.8
.650 334.6 210.8
.700 340.7 209.7
.750 346.5 210.8
.800 351.2 209.0
The sheet shows a port area of 3.76 sq in on intake and it shows
3.15 sq in on the exhaust.
So these flowed better then I remembered but not as Good as some of yours. I may need to have them checked out to see if they can be made better/bigger but with a blower app maybe it's not needed.
I have my wedge blocks O-ringed with a copper gasket and they seal Good so I may go that route with the hemi if possible just because of the possibility of getting a blower for it.
Any comments on these is Appreciated.
Thanks David
p.s. these seem like they might be decent for a street/strip 36 ply coupe even if I went N/A. Your Thoughts???
Re: hemi head what do I have??? [Re: His and Her 69's] #930864
02/23/11 05:17 AM
02/23/11 05:17 AM
Oh
Oh
Jeff,
Do you have a CNC program for these heads??
If so what are the max flow #'s when done??
I probably will be going N/A first to get the car running then as money allows get a blower.
Let me know about the CNC stuff Jeff, you can pm me if you want.
Thanks David
Re: hemi head what do I have??? [Re: His and Her 69's] #2002515
01/31/16 05:11 AM
01/31/16 05:11 AM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
does anyone knows the cc of the 3614433 heads
Re: hemi head what do I have??? [Re: His and Her 69's] #2002882
01/31/16 08:33 PM
01/31/16 08:33 PM
Cab_Burge Online work
Cab_Burge  Online Work
Jeff past away several years back, Bob runs MCH now and does a good job up
Re: hemi head what do I have??? [Re: Cab_Burge] #2009086
02/10/16 05:51 AM
02/10/16 05:51 AM
Oh
Oh
Cab this thread was brought back up. It was originally done in 2011 so Jeff was still around. I forgot all about this thread. Lol
Re: hemi head what do I have??? [Re: HEMIFRED] #2292648
04/23/17 12:29 PM
04/23/17 12:29 PM
New York
hurstdart Offline
hurstdart  Offline
New York
I am looking to purchase a late 1966 or early 1968 426 block, crank and rods preferably standard or .030 over bore.
Also, I noticed you have an A990 magnesium intake. Could you please email pictures.
Any parts if available would be helpful.
Thank you,
Ted
Re: hemi head what do I have??? [Re: His and Her 69's] #2292715
04/23/17 02:01 PM
04/23/17 02:01 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
The 433 is called the replacement head, aka twin plug head. This was the first aluminum head after the 65 heads. The ports had to be stock for use on 65 cars. Dual plug provisions for pro stock. This head was the everything head for Hemis for a long time, SS, top fuel, boats, pro stock, anybody that wanted to go fast. You buy them and send them to your favorite head porter, Mullins, Diamond, whatever. They are good heads and you can still send them out and have them ported and they will be anything you want. The problem is Edelbrock heads are the deal of the century. (They flow like ported 433 heads.) Edelbrock heads are the same price as ported 433 heads in 1975. Think about that. It's a good time to be a Hemi man.
2011 Drag Pak Challenger
Re: hemi head what do I have??? [Re: His and Her 69's] #2292720
04/23/17 02:12 PM
04/23/17 02:12 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Were those the Dart castings?
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: hemi head what do I have??? [Re: His and Her 69's] #2292727
04/23/17 02:31 PM
04/23/17 02:31 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
No
