Magnum Air-Gap vs Crosswind intake #2290652
04/19/17 06:14 PM
04/19/17 06:14 PM
the frozen wastes...
Pale_Roader Offline OP
Swears too much
Swears too much
Did a search and nothing came up.
Aside from the design differences, are there any actual performance differences? Magnumswap mentions smaller runners... smaller enough to make a HP difference?
I'm thinking a 5.2 or 5.9 Magnum with Whiplash cam, 670 Holley Street Avenger, Dougs or Super Comp headers (plus VERY good exhaust). Thats getting close to 400HP. Am i going to lose power/potential with the Crosswind?
Re: Magnum Air-Gap vs Crosswind intake [Re: Pale_Roader] #2290655
04/19/17 06:16 PM
04/19/17 06:16 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I have a crosswind on my 318. Seems to work fine. Times in my signature.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Magnum Air-Gap vs Crosswind intake [Re: Pale_Roader] #2290681
04/19/17 07:52 PM
04/19/17 07:52 PM
crabman173
crabman173
The volume of the runners is much less on the Crosswind--back to back dyno tests on a hyd roller cam street engine it came up almost 25 HP less than edelbrock in a 425HP engine volume is what matters--cross section of the runners is much less than the edelbrock Think of volume like this--intake is a cooler full of beer and 8 guys want plenty--bigger cooler is more beers everyone is happy I did the test on a 383 chevy but when I look the Mopar units seem to have the same disadvantage --smaller cross section and much smaller overall volume USA intake 1 China intake 1/2 it gets a 1/2 point for being so darn cheap I guess LOL
Re: Magnum Air-Gap vs Crosswind intake [Re: ] #2290688
04/19/17 08:15 PM
04/19/17 08:15 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
My engine is an enginemasters build. Find it hard to believe they left 25 horsepower on the table over a 200-300 dollar intake. My little motor would have busted 500 ponies at the competition most likely.
If that's true, I would buy the Edelbrock tomorrow.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Magnum Air-Gap vs Crosswind intake [Re: Pale_Roader] #2290740
04/19/17 10:08 PM
04/19/17 10:08 PM
Swears too much
Swears too much
Hmmm... . . . .
Re: Magnum Air-Gap vs Crosswind intake [Re: Pale_Roader] #2290745
04/19/17 10:27 PM
04/19/17 10:27 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Did a little checking around. Seems the LA airgap is indeed bigger.
But the magnum crosswind and magnum airgap are the same size according to several threads on another forum that were lengthy . Maybe there was confusion on that point, not sure.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Magnum Air-Gap vs Crosswind intake [Re: Pale_Roader] #2290914
04/20/17 11:05 AM
04/20/17 11:05 AM
Norfolk, NE
Racer33 Offline
Racer33  Offline
Norfolk, NE
I'm running the crosswind on my LA 360 in my vintage stockcar. The intake is drilled with both magnum and LA mounting patterns. I was pleased with the minimal amount it took to gasket match the intake.
Re: Magnum Air-Gap vs Crosswind intake [Re: Racer33] #2291314
04/20/17 11:39 PM
04/20/17 11:39 PM
Gainesville Fl
mphsmitch Offline
mphsmitch  Offline
Gainesville Fl
I ran both on my stock bottom end 360 several years ago with no ET difference.
90 Dakota 408 CID R/T heads 727 trans 9.5 converter 8.8 rear Pro 275/60 drag radials [email]11.09 @120mph[/email] N/A
Re: Magnum Air-Gap vs Crosswind intake [Re: Pale_Roader] #2291442
04/21/17 07:15 AM
04/21/17 07:15 AM
Swears too much
Swears too much
Well then... reason why i was asking, is that i NEED a swap intake for the Magnum i'm building... and there was a Crosswind advertised locally. I ended up picking it up today for the equivalent ov $110 US! Choke or not... i would have been WEE-TODD-DID to pass that up. Better... its brand new in the box, and with all hardware, hell... even the stickers are still there.
I took one look at it, and it looks stout. If the Edelbrock is any bigger, i'd be surprised. Better yet, LA-style water jacket. This thing should RUN.
Re: Magnum Air-Gap vs Crosswind intake [Re: Pale_Roader] #2291548
04/21/17 01:48 PM
04/21/17 01:48 PM
P
Porter67 Offline
Porter67  Offline
P
Thats a good buy, last week one sold on ebay nib and was at $165 us with a few hours to go.
