Cuda Shaker trim ring #2290352
04/19/17 12:13 AM
04/19/17 12:13 AM
New York
Mopucky Offline OP
Mopucky  Offline OP
New York
Is it possible to have an NOS shaker hood trim ring without a part number embossed in it? This one I can get is believed to be NOS yet I cant find a number on it anywhere. Any tips on finding out? Thanks!
Re: Cuda Shaker trim ring [Re: Mopucky] #2290355
04/19/17 12:26 AM
04/19/17 12:26 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I have never seen an original without one but I suppose it's possible. Originals have the studs cast into the ring (not studs added after casting) if the studs are cast as part of the ring its likely original. Keep in mind, the casting numbers are TINY! Post pics if you can.
Re: Cuda Shaker trim ring [Re: Mopucky] #2290359
04/19/17 12:37 AM
04/19/17 12:37 AM
New York
Mopucky Offline OP
Mopucky  Offline OP
New York
From what I recall the studs were cast with the ring. Felt like a heavy aluminum. Studs didn't appear to have nuts on them ever. Don't recall a part number as hard as I looked. It was in primer.
Are there any aftermarket known of that had the studs cast in?
I don't want to get burned buying it.
Re: Cuda Shaker trim ring [Re: Mopucky] #2290375
04/19/17 01:08 AM
04/19/17 01:08 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Here is an original, compare CLOSELY, I am guessing the one you found is a reproduction.
Re: Cuda Shaker trim ring [Re: ScottSmith_Harms] #2290423
04/19/17 04:51 AM
04/19/17 04:51 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
The rings we made were as good as it gets, however, they had part numbers and the Penta Star. I'm guessing it's a PG Classic, made from the same tooling as ours. Easiest way to tell, the threads on the studs are 10-32, originals were different. If the ring is from our tooling, use it, it's about as perfect to an original as it gets. I've seen our rings being sold as "NOS" on ebay.
Re: Cuda Shaker trim ring [Re: Mopucky] #2290443
04/19/17 08:02 AM
04/19/17 08:02 AM
New York
Mopucky Offline OP
Mopucky  Offline OP
New York
I'll try to get pics and look at it again. I'm going off memory of the last time I saw it. My first thought was reproduction at first but various things about it made me unsure.
Re: Cuda Shaker trim ring [Re: HEMICUDA] #2290559
04/19/17 01:55 PM
04/19/17 01:55 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
If it was your tooling how did someone else make parts off it?
Re: Cuda Shaker trim ring [Re: Morty426] #2290601
04/19/17 03:44 PM
04/19/17 03:44 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
They had some sort of partnership that allowed it IIRC.
Re: Cuda Shaker trim ring [Re: Morty426] #2290614
04/19/17 04:12 PM
04/19/17 04:12 PM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
The tooling was exclusive to us, under contract, for the production run of 400 licensed rings I made for Goodmark when they were going to make the Cuda shaker hood. They were also thinking about making Challenger rings, they pulled the plug on that one.
Is that OK?
Re: Cuda Shaker trim ring [Re: Mopucky] #2290615
04/19/17 04:12 PM
04/19/17 04:12 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
......If it was your tooling how did someone else make parts off it....
When BEA was at Carlisle one of the salesmen told me the 2 companies are 'manufacturing partners'.
Re: Cuda Shaker trim ring [Re: Mopucky] #2290811
04/20/17 01:17 AM
04/20/17 01:17 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
BTW, I can vouch for Mike's Cuda rings, they were very accurate and had the part# and Pentastar, extremely high quality parts unmatched by any other effort before or since!
Re: Cuda Shaker trim ring [Re: HEMICUDA] #2290982
04/20/17 01:07 PM
04/20/17 01:07 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Is that OK?
I spend a lot of time working in China so I'm cautious when someone makes parts off tooling I paid for to create knockoffs.
