Re: Cuda Shaker trim ring
[Re: ScottSmith_Harms]
#2290423
04/19/17 04:51 AM
04/19/17 04:51 AM
Posts: 1,923 Medina, Ohio
HEMICUDA
Medina, Ohio
The rings we made were as good as it gets, however, they had part numbers and the Penta Star. I'm guessing it's a PG Classic, made from the same tooling as ours. Easiest way to tell, the threads on the studs are 10-32, originals were different. If the ring is from our tooling, use it, it's about as perfect to an original as it gets. I've seen our rings being sold as "NOS" on ebay.
[Re: HEMICUDA]
#2290559
04/19/17 01:55 PM
04/19/17 01:55 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
The rings we made were as good as it gets, however, they had part numbers and the Penta Star. I'm guessing it's a PG Classic, made from the same tooling as ours. Easiest way to tell, the threads on the studs are 10-32, originals were different. If the ring is from our tooling, use it, it's about as perfect to an original as it gets. I've seen our rings being sold as "NOS" on ebay. If it was your tooling how did someone else make parts off it?
[Re: Morty426]
#2290601
04/19/17 03:44 PM
04/19/17 03:44 PM
Posts: 10,133 A Red State
SNK-EYZ
A Red State
The rings we made were as good as it gets, however, they had part numbers and the Penta Star. I'm guessing it's a PG Classic, made from the same tooling as ours. Easiest way to tell, the threads on the studs are 10-32, originals were different. If the ring is from our tooling, use it, it's about as perfect to an original as it gets. I've seen our rings being sold as "NOS" on ebay. If it was your tooling how did someone else make parts off it? They had some sort of partnership that allowed it IIRC.
[Re: Morty426]
#2290614
04/19/17 04:12 PM
04/19/17 04:12 PM
HEMICUDA
Medina, Ohio
The rings we made were as good as it gets, however, they had part numbers and the Penta Star. I'm guessing it's a PG Classic, made from the same tooling as ours. Easiest way to tell, the threads on the studs are 10-32, originals were different. If the ring is from our tooling, use it, it's about as perfect to an original as it gets. I've seen our rings being sold as "NOS" on ebay. If it was your tooling how did someone else make parts off it? The tooling was exclusive to us, under contract, for the production run of 400 licensed rings I made for Goodmark when they were going to make the Cuda shaker hood. They were also thinking about making Challenger rings, they pulled the plug on that one. Is that OK?
[Re: HEMICUDA]
#2290982
04/20/17 01:07 PM
04/20/17 01:07 PM
Morty426
Sacramento CA
The rings we made were as good as it gets, however, they had part numbers and the Penta Star. I'm guessing it's a PG Classic, made from the same tooling as ours. Easiest way to tell, the threads on the studs are 10-32, originals were different. If the ring is from our tooling, use it, it's about as perfect to an original as it gets. I've seen our rings being sold as "NOS" on ebay. If it was your tooling how did someone else make parts off it? The tooling was exclusive to us, under contract, for the production run of 400 licensed rings I made for Goodmark when they were going to make the Cuda shaker hood. They were also thinking about making Challenger rings, they pulled the plug on that one. Is that OK? I spend a lot of time working in China so I'm cautious when someone makes parts off tooling I paid for to create knockoffs.
