NHRA 2 year belt life
#2287342
04/13/17 11:14 PM
04/13/17 11:14 PM
Posts: 632 Casco, MI
Savoy1964
Casco, MI
So my existing belts have a date of 05-15 so these belts are good until 05-17 correct?
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: NHRA 2 year belt life
[Re: Savoy1964]
#2287488
04/14/17 05:04 AM
04/14/17 05:04 AM
Guitar Jones
[Re: Savoy1964]
#2287491
04/14/17 05:26 AM
04/14/17 05:26 AM
Posts: 301 CA
David Lee
CA
when i have out of date belts, i sell them to some of the short dirt track guys. they seem not to have the same bs as the nhra does
Ah...so many pedestrians, so little time...
[Re: Savoy1964]
#2287509
04/14/17 09:10 AM
04/14/17 09:10 AM
Savoy1964
Casco, MI
Thanks for he replies i figured they were done but at least i can get these re-certified, RJS Racing does it, but they need to be sent to there Florida store.
[Re: Savoy1964]
#2288078
04/15/17 08:49 AM
04/15/17 08:49 AM
Savoy1964
Casco, MI
Comes to about 139 with shipping to re-cert so i might just purchase new belts but the window net need to be replaced and that is a custom fit.
[Re: Savoy1964]
#2288537
04/16/17 12:56 AM
04/16/17 12:56 AM
Savoy1964
Casco, MI
I have had mine looked at in tech the car can do the ET to need a net but i have a restrictor plate to keep it around 10.0 still runs 138 mph.
[Re: Savoy1964]
#2288676
04/16/17 11:43 AM
04/16/17 11:43 AM
Posts: 9,848 MI, usa
dvw
MI, usa
Comes to about 139 with shipping to re-cert so i might just purchase new belts but the window net need to be replaced and that is a custom fit. Window nets no longer require update. NHRA dropped the recert. Doug
[Re: Savoy1964]
#2288871
04/16/17 03:21 PM
04/16/17 03:21 PM
Savoy1964
Casco, MI
hmmmm then why do they still re-cert them at RJS Racing?
A ribbon-type or SFI 27.1 mesh-type window net is mandatory for any full-bodied car running 7.50 (*4.50) to 9.99 (*6.39) or if vehicle runs 135 mph or faster. See General Regulations 6:3
found this in the 2017 rule book.
Granted I am keeping car at 10.0 so i would guess i don't even need a net at this point.
[Re: Savoy1964]
#2289109
04/16/17 11:08 PM
04/16/17 11:08 PM
Savoy1964
Casco, MI
well I won't take the chance on belts both Columbus and Norwalk have never missed checking dates on belts they even look at grounds on fuel cell and chassis cert. The net I think I can forget about as long as I keep it at 10.0
[Re: Savoy1964]
#2289230
04/17/17 02:41 AM
04/17/17 02:41 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
well I won't take the chance on belts both Columbus and Norwalk have never missed checking dates on belts they even look at grounds on fuel cell and chassis cert. The net I think I can forget about as long as I keep it at 10.0 I dont blame you as I dont race alot but it sounds like you do and if you know they are going to check them then I would do as you are doing. Myself I only race once or twice a year so I dont get many passes before my belts go out of date. I really wish they would push it to 5 years. Even though my car is mostly a street driven car its in the garage when I am not driving it so I really dont see no reason they could not push belts to every 5 years. Ron
[Re: Savoy1964]
#2289269
04/17/17 08:55 AM
04/17/17 08:55 AM
Savoy1964
Casco, MI
I also think the 2 year rule is a little crazy I am similar except this car is strictly race no street and sits in a garage while not racing so i get 30 to 40 runs in two years and my belts are worn out.... I think not.
[Re: Savoy1964]
#2289304
04/17/17 11:03 AM
04/17/17 11:03 AM
Posts: 19,470 north of coder
moparx
yet, unless i'm totally out in left field, OE 45 year belts are ok to x.xx [?] et, and newer stuff to a lower et ? why aren't those mandatory to be changed out ? then, there are some tracks that allow aftermarket belts that are out of date to run to x.xx et, and some toss you out if you have aftermarket belts and only run 15.00 and slower. i know safety is a paramount concern, but if military aircraft can go way more years than a 10.00 car before a change out, and fast dirt cars the same, there is no reason for nhra to mandate a two year rule on belts except money being involved.
