Re: Diaper or Catch Pan For Early B-Body [Re: BigFish69] #2291001
04/20/17 01:34 PM
04/20/17 01:34 PM
North of Detroit
HemiDart68 Offline
HemiDart68  Offline
North of Detroit
Originally Posted By BigFish69
Matt
whats the rear of the pan bolted to I see the front is bolted to the K member any rear pics
thanks Tom
For the rear we used an aluminum plate bolted to the transmission, in place of the torque converter inspection plate/cover that hangs down the depth of the pan. The plate has mounting provisions that the rear of the belly pan bolted up to.
In God we trust, all others pay cash. www.lightnens.com (Home of the world's fastest Paint Job)
Re: Diaper or Catch Pan For Early B-Body [Re: Clanton] #2291008
04/20/17 01:48 PM
04/20/17 01:48 PM
North of Detroit
HemiDart68 Offline
HemiDart68  Offline
North of Detroit
Originally Posted By Clanton
Do you have any thoughts on closing the sides of the K member to direct oil to the sump?
I have thought about doing that. The NHRA rule book for belly pans states something along the lines of the pan covering from frame rail to frame rail. Easy in a chassis car or dragster, not possible in a stock front suspension. I think closing off the K frame on the sides could bring it more in-line the rule, and the argument could be made that by utilizing the k frame and oil catch pan in this manner meets the intent of the frame rail to frame coverage. Might end up making block off plates at some point, especially if I raced regularly. I'm more interested in have a street car lately. I know a few people with similar setups that race regularly and never had an issue with tech. Its all about doing the best you can, no setup diaper or pan is perfect when dealing with stock suspension mopar with a steering link going through the pan.
Re: Diaper or Catch Pan For Early B-Body [Re: tboomer] #2291055
04/20/17 03:34 PM
04/20/17 03:34 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Thank you for the reply,Ya do what you can and adjust along the way.
Re: Diaper or Catch Pan For Early B-Body [Re: HemiDart68] #2291108
04/20/17 05:21 PM
04/20/17 05:21 PM
tboomer Offline OP
tboomer  Offline OP
That looks very good! Nice work! wave
Re: Diaper or Catch Pan For Early B-Body [Re: tboomer] #2291154
04/20/17 07:00 PM
04/20/17 07:00 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I just cut the "k" and set back the engine some.I really dig your vision and will follow in your footsteps!! Thanks for posting that up
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Diaper or Catch Pan For Early B-Body [Re: hemi-itis] #2291183
04/20/17 07:49 PM
04/20/17 07:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Put a radius at the end of those cuts so it doesnt
crack
wave
Re: Diaper or Catch Pan For Early B-Body [Re: tboomer] #2291386
04/21/17 01:36 AM
04/21/17 01:36 AM
hemi-itis Offline
hemi-itis  Offline
Been thinking about this all afteroon workI really like that belly pan that fits in the notched "k".But the diaper also cover the sides of the block.If something blows hard enough to go through the oil pan it will go through that pan also,,,,,,,,
Re: Diaper or Catch Pan For Early B-Body [Re: hemi-itis] #2291747
04/21/17 07:30 PM
04/21/17 07:30 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Maybe some Kevlar sheets glued to that pan
Re: Diaper or Catch Pan For Early B-Body [Re: tboomer] #2291828
04/21/17 11:00 PM
04/21/17 11:00 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I wonder if a stamped side engine cover can be used on both sides.
Re: Diaper or Catch Pan For Early B-Body [Re: dvw] #2292027
04/22/17 11:57 AM
04/22/17 11:57 AM
montana
BANDIT Offline
BANDIT  Offline
montana
Not to hi-jack but DRW, is that an Aerospace mandrel for your alt and vacuum pump? I noticed you have a spacer holding it away from the crank trigger wheel. I am wondering how to do mine without having everything all bolted together as one unit. Jim.
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
