Originally Posted By tboomer
Whats the preference here? Diaper or Catch pan for my 64? Pictures would be great! Thanks!! Ted wave
Ted.. there is no best answer here.. its what will
work easiest for you.. they both will do the same
job if done right.. on my junk the pan is easier..
and smooths out the air flow under the car... for
others the diapers are easier but make sure you get
one that wont burn in high temp areas and no plastic
strap connections.. I remember one that Hemi Fred had
that has plastic parts that didnt last
wave
