Re: Modified oil pump failure
[Re: MR_P_BODY]
#2282589
04/05/17 12:20 AM
04/05/17 12:20 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
2 things.. whats the weight oil and what is the minimum rpm you see 80# I run 10w30 Lucas synthetic.. and to be honest most of the racing I do is 1/8 Mile at night.. and it's very hard to get a bead on the gauges... from a few videos that I have watched... at speed the Gage is always around 80.... typically idles 1500rpm at 55lb hot
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: rickraw]
#2282593
04/05/17 12:22 AM
04/05/17 12:22 AM
WHITEDART
bean town ....Ca
Shiloh, maybe when the pan got crushed it may have fractured the pump & it finally broke off. hey Rick good to see you around... and yes this has kind of been our thought to.... mr. P are you suspecting pressure
[Re: WHITEDART]
#2283045
04/05/17 09:34 PM
04/05/17 09:34 PM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
The passage is way off center too. One more thing to check. I'll be looking at all of mine this weekend.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
[Re: qwkmopardan]
#2283197
04/06/17 02:58 AM
04/06/17 02:58 AM
WHITEDART
bean town ....Ca
How big is the outlet hole opened up to? I allways open them to 1/2" and never had this happen. I have had pick-up tube break off and fall in the pan, but never the pump. I see yours has the pick-up in cover, just like the set-up in my Demon. mine was just a tick larger at 17/32...this oil pump has had a ruff ride..may the next one will have a belt..
[Re: Thumperdart]
#2283198
04/06/17 03:05 AM
04/06/17 03:05 AM
WHITEDART
bean town ....Ca
Sorry to see this after all of the other bs you went through man and hopefully it's repairable...........that thing flies and you should be proud of your efforts and results so far...... the crank was fine I will ship the rods to Oliver... I think I can buy two and have them put new bushings and new bolts in the others.. I think I'm going to step up on compression... this motor was originally built for bracket racing. and e85 but I never expected it to run this fast.. now I'm caught up in the heads Up Racing stuff..so time will tell..
[Re: WHITEDART]
#2283202
04/06/17 03:23 AM
04/06/17 03:23 AM
Thumperdart
State of confusion
Good news there........... ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) Good luck man............
[Re: WHITEDART]
#2283204
04/06/17 03:40 AM
04/06/17 03:40 AM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
Glad to hear it appears to be not so bad...No better time to step up the game than now.
[Re: WHITEDART]
#2283503
04/06/17 06:32 PM
04/06/17 06:32 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
This weekend did not end up so good.. although I guess we could say it could have been worse.. the Car slow down almost for tenths on its last pass.. after picking up my losing time slip.. re fired the motor and noticed it didn't have any oil pressure.. and the starter really struggled to start it... I got it home.. remove the oil pump and found the oil pump Lane in the oil pan Is that a crack on the left where the oil pump cover bolt goes in? Matt
