Help me build a 9" #2281998
04/04/17 02:01 AM
04/04/17 02:01 AM
Janesville, WI
SpareParts Offline OP
Janesville, WI
Well, I'm pushing the 8.75 hard enough and i want a better mousetrap. I have a nice 9" fabbed housing and aluminium bolt through center section.
I want to make it stock A body width so I don't have to get wheels right now $$$ Is there any way I can do it and use my current axles and brakes? Like if I put Mopar ends on it? Would i be cutting down one axle to do it??
Thanks guys
Re: Help me build a 9" [Re: SpareParts] #2282043
04/04/17 07:18 AM
04/04/17 07:18 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Not sure of the 9" pinion offset. If it's not to much why not. I did the same with a Dana 60. Used the old housing ends and 35 spline axles from a previous 8 3/4. Had to make the housing 1" narrower do to pinion offset. Didn't even trim the longer axle on the short side of the housing, just stuck it in further.
Doug
Re: Help me build a 9" [Re: SpareParts] #2282188
04/04/17 01:24 PM
04/04/17 01:24 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
I did exactly what you are talking about I used mopar ends to use both my Strange 35 spline axles and my Wilwood brakes. Use of your axles will depend on whether the splines go completely through your spool and how long the splines are on the axles. Mine all fit together nicely so I saved a bunch of money..
Re: Help me build a 9" [Re: SpareParts] #2282427
04/04/17 08:20 PM
04/04/17 08:20 PM
Janesville, WI
Janesville, WI
That's what I want to hear! Everything is 35 spline so hopefully it works
Re: Help me build a 9" [Re: SpareParts] #2283083
04/05/17 10:50 PM
04/05/17 10:50 PM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
im building a 9" to replace my 8 3/4 as well and am going to be able to use my 40 spline moser shafts and housing ends off of the 8 3/4. if you need any 9" parts quick performance is the cheapest that i have found by far
Re: Help me build a 9" [Re: SpareParts] #2283152
04/06/17 01:03 AM
04/06/17 01:03 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
If I recall correctly, spline shape and placement in the spool, is different than others when using Mark Williams parts. You may want to confirm that, but that seems to be rattling in my brain.
Re: Help me build a 9" [Re: SpareParts] #2283265
04/06/17 10:46 AM
04/06/17 10:46 AM
an8sec70cuda Offline
Yep, Mark Williams has their own unique splines. Their axles will only work in their spool. Other company's parts interchange...Strange spool w/ Moser axles, etc.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Help me build a 9" [Re: SpareParts] #2286657
04/12/17 10:07 PM
04/12/17 10:07 PM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
the shafts and spool were moser, thanks for the heads up. i had asked both moser and quick performance before ordering parts.they said the same thing about mark williams.
Re: Help me build a 9" [Re: upnover] #2286666
04/12/17 10:19 PM
04/12/17 10:19 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
Upnover, I upgraded my 9" a couple of yrs ago to 40 spline after twisting up the 35's. As I recall, you have to buy the large ford housing ends, because you have to use the large ford bearing to fit the dia. of a 40 spline axel.
Re: Help me build a 9" [Re: SpareParts] #2286925
04/13/17 10:27 AM
04/13/17 10:27 AM
FWIW...I've seen a bunch of twisted and broken Strange axles, but not Mosers.
CHIP
