Re: Vinyl dye
[Re: GKMOPAR]
#2271006
03/17/17 08:08 AM
03/17/17 08:08 AM
Posts: 1,795 Greer, SC
TooMany62s
Greer, SC
At least some auto paint stores can mix vinyl die in any color you wish. You may need to check with some of your local stores. On the other hand some of the interior stuff in these older cars didn't match very well from the beginning.
Re: Vinyl dye
[Re: GKMOPAR]
#2278996
03/30/17 05:34 PM
03/30/17 05:34 PM
Posts: 8,879 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
SEM is a paint, not a dye. To my knowledge you cannot dye vinyl Actually SEM is a "flexible vinyl coating" You are correct in that you cannot "dye" vinyl since its not porous. BUT, SEM is the closest you're going to get to a product that will change the color of vinyl. I'd use SEM just about anywhere ... EXCEPT seats. Unless you don't mind doing them every year !!
Re: Vinyl dye
[Re: Stanton]
#2279708
03/31/17 05:41 PM
03/31/17 05:41 PM
DaytonaTurbo
Manitoba, Canada
Sounds like a marketing term for paint. I've used it before with good luck on dash boards. I have seen it scuff off higher abrasion areas like kick panels, never seen it used on a seat however I have read some claims that it works ok if used with the adhesion promoter. I would sooner put the money towards new seat covers, enough SEM + adhesion promoter isn't exactly cheap.
