What Valves for RHS LA X Heads? #2278420
03/29/17 05:29 PM
03/29/17 05:29 PM
Oregon City, OR
Baxter61 Offline OP
Baxter61  Offline OP
Oregon City, OR
I have two sets that are needing some valves, what are ya'll using in them? My understanding is the popular way to set them up is with a 1.800 installed height beehive spring, but its hard to get the 1.800 installed height because you cant cut into the spring pocket very deep. Looking at 2.02s on the intake unless I cant be talked into bigger, although wasnt planning on porting them.
Re: What Valves for RHS LA X Heads? [Re: Baxter61] #2278492
03/29/17 08:01 PM
03/29/17 08:01 PM
lancaster,california
johnnycuda Offline
johnnycuda  Offline
I bought my heads from Brian at IMM in Indio, Ca., they're 2.02"/1.60", beehive, not sure of installed height, metric valve stem I believe.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: What Valves for RHS LA X Heads? [Re: Baxter61] #2279147
03/30/17 10:06 PM
03/30/17 10:06 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
They are a 8mm stem or 5/16 stem, ferrea makes the valves, and comp makes a 1.81 installed height beehive spring, for a standard valve spring pocket, i run them on stock 318 heads.
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: What Valves for RHS LA X Heads? [Re: 65signet] #2279420
03/31/17 10:38 AM
03/31/17 10:38 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Great little heads, but set up is a bit of a pain. Easiest thing to do is ream them to 11/32, and use common SBC valves, much more options. If you want to stick with 5/16, less options, or at least they are more expensive options.
RIP Monte Smith
Re: What Valves for RHS LA X Heads? [Re: 65signet] #2279510
03/31/17 12:48 PM
03/31/17 12:48 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Yes, what 65signet said. I have used the same valve and a Comp 26995 spring at 1.81" IH on both an Indy RHS head and an EQ head.
Re: What Valves for RHS LA X Heads? [Re: Baxter61] #2279615
03/31/17 03:22 PM
03/31/17 03:22 PM
Oregon City, OR
Baxter61 Offline OP
Baxter61  Offline OP
Oregon City, OR
Thanks guys, do you know what length valves? Im kinda digging the 11/32 idea. I have some PAC beehive springs and retainers that want a 1.8 install height id like to use if i can
Re: What Valves for RHS LA X Heads? [Re: Baxter61] #2279672
03/31/17 04:35 PM
03/31/17 04:35 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
How much lift are you after? I am running stock length stainless valves 2.02 1.65 from hughes with their springs and retainers at .575 lift (theoretical) and it still clears the stock guide to boot.
As for diameter I would not go any bigger because the valves are so close but maybe you could go with a 2.05 1.60 or something but you need to open the bowl and chamber quite a bit as well as your bore should probably be bigger than my 4.04 to make any use of that. I would just run the 2.02 and open the chamber to the edge of your bore.
Re: What Valves for RHS LA X Heads? [Re: HotRodDave] #2279678
03/31/17 04:42 PM
03/31/17 04:42 PM
Oregon City, OR
Baxter61 Offline OP
Baxter61  Offline OP
Oregon City, OR
Thats pretty much the plan right now is to run them on a 4.04 bore. As for lift Ive mostly been looking at mid-.550-.590 lift cams. I just didnt know what the stock length for these heads was, if it matched a regular LA head or not.
