Re: Cam Bolt and Upper Control Arm Bushing Fit
[Re: solarguy]
#2278157
03/29/17 02:47 AM
03/29/17 02:47 AM
Posts: 4,848 Memphis
HemiRick
Memphis
This doesnt matter IMHO as the bolts are only there to hold the stuff together and allow alignment to be adjusted....When they are tight....the bolts clamp the inner tubes of the bushings in place and there is no slop.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#2278230
03/29/17 10:56 AM
03/29/17 10:56 AM
Posts: 1,286 Ft. Lauderdale, FL
solarguy
Ft. Lauderdale, FL
This doesnt matter IMHO as the bolts are only there to hold the stuff together and allow alignment to be adjusted....When they are tight....the bolts clamp the inner tubes of the bushings in place and there is no slop. That seems to be how the design is intended. I'm just playing with the new parts and mocking things up. I expected the bolt to fit the bushing with much less slop.
