Re: Metal Inserts for Wiper Blade Refills
[Re: Mattax]
#2276293
03/26/17 01:52 AM
03/26/17 01:52 AM
fury4speed
[Re: MuuMuu101]
#2276891
03/27/17 12:25 AM
03/27/17 12:25 AM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
that one of the metal inserts that hold the refill in fell off. Does anyone know where to get these? I thought this was the problem you were trying to solve. Well, don't toss the Anco anti-lift push button blades - someone will want them.
[Re: Mattax]
#2276893
03/27/17 12:26 AM
03/27/17 12:26 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
that one of the metal inserts that hold the refill in fell off. Does anyone know where to get these? I thought this was the problem you were trying to solve. Well, don't toss the Anco anti-lift push button blades - someone will want them. That was my question, but no one answered it.
[Re: MuuMuu101]
#2277041
03/27/17 11:09 AM
03/27/17 11:09 AM
Mattax
Phila. Pa.
Pretty hard without knowing what you had/have. Now at least its possible to make a guess that the 'metal insert' might have referred to the spring clip used on some universal refills to adapt them to the push-locks. (shown on the right side of this photo). Can't see enough in your photo. It does look like the refill is sticking out an 1" from the blade. Like I posted above some people appreciate the original stuff so you'll find a buyer if you don't want to keep it. Can't help you on the "classic", never used them. A Trico 43 series is a universal replacement that although little narrow and a fraction long, is the type I've used in the past. There might be a wider version but I stopped looking after picking up a set of correct old stock. Something like these should be the correct fit. http://www.ebay.com/itm/331639757032?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649But old stock is what it is. Its not for everyone or all situations. Just letting you know its there if you want it.
[Re: MuuMuu101]
#2277296
03/27/17 06:56 PM
03/27/17 06:56 PM
Posts: 959 Chicago
PurpleBeeper
Chicago
Wow....I've made customer wiper blade for customers many times. Are these wipers for a Dart? My 70 B-body wiper blade frames don't come apart from the wiper arms themselves, so re-fill is my only option.
You probably already figured this out, but just cut the blades themselves with a razor & cut the metal inserts along the sides with snips & "done". On my 70, I have a little tab at the end of the wiper backing ("bracket" I think you call it) that I have to "snake" the refill past... sort of a little metal tab that keeps the refill from sliding out the end.
If YOUR wiper arm has a "U-hook" at the end of it, then almost all modern replacement wipers (blade + backing) will fit. "Some" cars need a little plastic adapter/insert for odd-sized "U-hooks" (Mercedes & BMW are like this a lot) and O'Reilly has a case of free adapters behind the counter.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: stumpy]
#2277439
03/27/17 11:43 PM
03/27/17 11:43 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
You probably already figured this out, but just cut the blades themselves with a razor & cut the metal inserts along the sides with snips & "done". On my 70, I have a little tab at the end of the wiper backing ("bracket" I think you call it) that I have to "snake" the refill past... sort of a little metal tab that keeps the refill from sliding out the end. I could do this method, but I am still missing one side of the metal inserts. I have tabs at both ends of my wiper backing. In order to slide the 16" I had to straighten the tab on one side; hence why I'm having issues with the refills falling off.
[Re: stumpy]
#2277440
03/27/17 11:43 PM
03/27/17 11:43 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Most of the new replacement blades come with adapters as part of the package. I don't recall what I bought a couple of years ago before this 16" refill, but I remember it came with adapters, none of which worked.
[Re: MuuMuu101]
#2277479
03/28/17 01:07 AM
03/28/17 01:07 AM
Mattax
Phila. Pa.
I still can't figure out what is missing. If you're using the original wiper, the original refill is held by the raised section. Here's a picture of a 1970 on FABO [img] https://www.forabodiesonly.com/mopar/attachments/dscn0867-jpg.1714700597/[/img] If you're using a different style refill with a spring clip on the end(picture linked in my earlier post), the spring clips come with new ones. The correct refill length is 15".
