Metal Inserts for Wiper Blade Refills #2276206
03/25/17 09:37 PM
03/25/17 09:37 PM
SoCal
MuuMuu101 Offline OP
I got lucky at Woodward!
SoCal
It seems that one of the times where I used the windshield wipers and drove the Dart in like-rainy conditions that one of the metal inserts that hold the refill in fell off. Does anyone know where to get these? Or do they come with the wiper refill when you order them?
https://www.summitracing.com/int/parts/anc-19-15/overview/
Re: Metal Inserts for Wiper Blade Refills [Re: MuuMuu101] #2276211
03/25/17 09:46 PM
03/25/17 09:46 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Why not just go the the local parts store and buy your refills. shruggy
Re: Metal Inserts for Wiper Blade Refills [Re: stumpy] #2276217
03/25/17 10:00 PM
03/25/17 10:00 PM
SoCal
SoCal
As far as I know, the big stores around here (NAPA, O'Reilly, Pepboys, etc.) don't carry any refills, just the full plastic blades for more modern cars.
Re: Metal Inserts for Wiper Blade Refills [Re: MuuMuu101] #2276263
03/25/17 11:25 PM
03/25/17 11:25 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Post a picture of the blade. Too many variations to guess what you've got and what fell off. If its the original blade, then its a 15" ANCO 'push button' which was IMO a clever design. AFIAK the correct refill is only available new in 16". Metal rib on a correct 'refill' as should be 0.380" wide. But yours may have something else, a later replacement, so got to figure out what you got first.
Re: Metal Inserts for Wiper Blade Refills [Re: Mattax] #2276293
03/26/17 12:52 AM
03/26/17 12:52 AM
fury4speed Offline
fury4speed  Offline
Re: Metal Inserts for Wiper Blade Refills [Re: MuuMuu101] #2276802
03/26/17 09:43 PM
03/26/17 09:43 PM
New York
rarefish Offline
rarefish  Offline
New York
Rock Auto has the 15" Trico Classics.
Re: Metal Inserts for Wiper Blade Refills [Re: rarefish] #2276851
03/26/17 10:41 PM
03/26/17 10:41 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I bought cut to fit blades at my local Advance Auto as you cannot find any 15" blades in a pinch. I wanted to use my original arms so I had no choice. I forgot how long the are, but not long enough for 2-15" sections. frown
JB Rhinehart, Realist
A-Body's RULE!
Re: Metal Inserts for Wiper Blade Refills [Re: MuuMuu101] #2276869
03/26/17 10:54 PM
03/26/17 10:54 PM
SoCal
SoCal
Sorry for the lack of response. I am pretty sure I have the original Anco windshield wiper frames. I have replaced the blades before for 16" blades, they don't really work too well and hang off the edge an extra inch. IIRC, I think a fried of mine at the local car show gave me these metal inserts.
Since, I just happen to drive by an O'Reilly on my way home today I checked to see if they had the TricoClassic blades and they had two. It looks like a better quality than my blade; however, I'm not really sure how they attach and don't want to fiddle too much with them in case I need to return them.
So, how do these fit on exactly? It seems like mine have a tab that locks the blade into a fixture where the new ones have a spring clip of sorts.
Windshield Wiper 1.jpgWindshield Wiper 2.jpgWindshield Wiper 3.jpgWindshield Wiper 4.jpg
Re: Metal Inserts for Wiper Blade Refills [Re: MuuMuu101] #2276891
03/26/17 11:25 PM
03/26/17 11:25 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
I thought this was the problem you were trying to solve.
Well, don't toss the Anco anti-lift push button blades - someone will want them.
Re: Metal Inserts for Wiper Blade Refills [Re: Mattax] #2276893
03/26/17 11:26 PM
03/26/17 11:26 PM
SoCal
SoCal
That was my question, but no one answered it.
Re: Metal Inserts for Wiper Blade Refills [Re: MuuMuu101] #2277041
03/27/17 10:09 AM
03/27/17 10:09 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Pretty hard without knowing what you had/have.
Now at least its possible to make a guess that the 'metal insert' might have referred to the spring clip used on some universal refills to adapt them to the push-locks. (shown on the right side of this photo). Can't see enough in your photo. It does look like the refill is sticking out an 1" from the blade.
Like I posted above some people appreciate the original stuff so you'll find a buyer if you don't want to keep it. Can't help you on the "classic", never used them.
A Trico 43 series is a universal replacement that although little narrow and a fraction long, is the type I've used in the past. There might be a wider version but I stopped looking after picking up a set of correct old stock.
Something like these should be the correct fit.
http://www.ebay.com/itm/331639757032?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649
But old stock is what it is. Its not for everyone or all situations. Just letting you know its there if you want it.
Re: Metal Inserts for Wiper Blade Refills [Re: MuuMuu101] #2277144
03/27/17 12:51 PM
03/27/17 12:51 PM
SoCal
SoCal
So, I guess what I'm talking about is the long metal insert that runs all the way across the side of the rubber blade to hold it on the sliders.
If you look closely at my last picture where I compare the new vs old, the right hand side of my old blade sits flush with the end of my frame, whereas the left sticks out about an inch. The few times I had to use my windshield wiper, the rubber blades started to fall off because of this.
Re: Metal Inserts for Wiper Blade Refills [Re: MuuMuu101] #2277145
03/27/17 12:55 PM
03/27/17 12:55 PM
SoCal
SoCal
If you zoom into the 3rd photo, hard to see, but you can see that the old bracket is held on by a bow tie shaped tab while the new one has a "spring clip" situating it.
Re: Metal Inserts for Wiper Blade Refills [Re: MuuMuu101] #2277251
03/27/17 03:49 PM
03/27/17 03:49 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Rain-X is our friend
Re: Metal Inserts for Wiper Blade Refills [Re: MuuMuu101] #2277296
03/27/17 05:56 PM
03/27/17 05:56 PM
Chicago
PurpleBeeper Offline
Chicago
Wow....I've made customer wiper blade for customers many times. Are these wipers for a Dart? My 70 B-body wiper blade frames don't come apart from the wiper arms themselves, so re-fill is my only option.
You probably already figured this out, but just cut the blades themselves with a razor & cut the metal inserts along the sides with snips & "done". On my 70, I have a little tab at the end of the wiper backing ("bracket" I think you call it) that I have to "snake" the refill past... sort of a little metal tab that keeps the refill from sliding out the end.
If YOUR wiper arm has a "U-hook" at the end of it, then almost all modern replacement wipers (blade + backing) will fit. "Some" cars need a little plastic adapter/insert for odd-sized "U-hooks" (Mercedes & BMW are like this a lot) and O'Reilly has a case of free adapters behind the counter.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Metal Inserts for Wiper Blade Refills [Re: MuuMuu101] #2277308
03/27/17 06:18 PM
03/27/17 06:18 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Most of the new replacement blades come with adapters as part of the package.
Re: Metal Inserts for Wiper Blade Refills [Re: stumpy] #2277439
03/27/17 10:43 PM
03/27/17 10:43 PM
SoCal
SoCal
I could do this method, but I am still missing one side of the metal inserts. I have tabs at both ends of my wiper backing. In order to slide the 16" I had to straighten the tab on one side; hence why I'm having issues with the refills falling off.
Re: Metal Inserts for Wiper Blade Refills [Re: stumpy] #2277440
03/27/17 10:43 PM
03/27/17 10:43 PM
SoCal
SoCal
I don't recall what I bought a couple of years ago before this 16" refill, but I remember it came with adapters, none of which worked.
Re: Metal Inserts for Wiper Blade Refills [Re: MuuMuu101] #2277479
03/28/17 12:07 AM
03/28/17 12:07 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
I still can't figure out what is missing.
If you're using the original wiper, the original refill is held by the raised section. Here's a picture of a 1970 on FABO
[img]https://www.forabodiesonly.com/mopar/attachments/dscn0867-jpg.1714700597/[/img]
If you're using a different style refill with a spring clip on the end(picture linked in my earlier post), the spring clips come with new ones. The correct refill length is 15".
Re: Metal Inserts for Wiper Blade Refills [Re: MuuMuu101] #2277509
03/28/17 01:23 AM
03/28/17 01:23 AM
SoCal
SoCal
I have more pictures and possibly some clarification. My last refill, I ordered the wrong length refill as shown. I have a 16" refill blade on a 15" assembly.
Re: Metal Inserts for Wiper Blade Refills [Re: MuuMuu101] #2277511
03/28/17 01:24 AM
03/28/17 01:24 AM
SoCal
SoCal
The TricoClassics will not work as they mount to the arm completely differently.
Re: Metal Inserts for Wiper Blade Refills [Re: MuuMuu101] #2277513
03/28/17 01:25 AM
03/28/17 01:25 AM
SoCal
SoCal
I am missing the metal sleeve that goes on either side of the refill to give the rubber rigidity. If I have to order a 15" refill anyway, I am assuming that the metal sleeves come with the refill.
Re: Metal Inserts for Wiper Blade Refills [Re: MuuMuu101] #2277515
03/28/17 01:42 AM
03/28/17 01:42 AM
SoCal
SoCal
Pictures of my blades and arms for reference.
Windshield Wiper 10.jpgWindshield Wiper 11.jpgWindshield Wiper 12.jpgWindshield Wiper 13.jpg
Re: Metal Inserts for Wiper Blade Refills [Re: MuuMuu101] #2277584
03/28/17 09:09 AM
03/28/17 09:09 AM
moparx Online content
Buying your homeless and unwanted bolt on battery terminals
moparx  Online Content
how much of that side shim stuff do you need ? i have a bunch of that stuff in my "wiper parts" drawers. hundreds of years ago, i attended an auction and ended up with a lifetime supply of blades and refills, and used up a bunch of it already, but still have three drawers full of stuff ranging from 6-24". many times, i have taken the refills apart and used the rubber without needing the shims [side reinforcements]. let me know how much of that stuff you need, and i'll send it to you, gratis, provided you can wait a few days.
beer
Re: Metal Inserts for Wiper Blade Refills [Re: MuuMuu101] #2277615
03/28/17 10:34 AM
03/28/17 10:34 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
OK. I think the crux of the problem was that it was too narrow of a refill. The trick will be to find a new refill of the correct width.
Use a caliper, machinist or drafting rule to check these dimensions-
Correct Refill Dimensions:
Width of refill reinforcing rib (usually metal) is 0.380"
Length of refill reinforcing rib is 15 1/16"
Length of refill rubber wiper 14 13/16"
Raised section in middle (distance between wiper's claws) 4 9/16"
Ht from windshield contact edge to rib .42"
A somewhat close replacement seems to be Trico 43-150
Width of refill reinforcing rib .34" with two sections in middle at .4
Width of spring retaining clip on tip, approx .38 -.4 (free)
Length of steel rib: 15 1/8"
Length of rubber: about 15"
No raised section, retension by clip on tip.
Ht from windshield to rib: .41"
There may be better fitting refills but that's what I've come up with so far. Maybe Moparx will have something for you.
Classic Industries has new refills for 16" Anco push buttons. If someone has the correct 15" rib, it *might* be possible to cut the new 16" rubber to fit into the 15" rib.
The problem with buying correct old stock is that the rubber may be dried out and brittle. You don't know until you get it. I did it to get the measurements and it happened to be in decent condition.
Trico 43-150 refill, end tips
Re: Metal Inserts for Wiper Blade Refills [Re: MuuMuu101] #2277623
03/28/17 10:49 AM
03/28/17 10:49 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Cross referencing:
Analysing the parts books..
In 1967 all A-bodies got 15" Anco push button wipers; But in 1968 A-bodies could have ANCO with two claws (bridges) or Trico with single bridge. The Anco refills for 1967 and '68 are the same.
The B-bodies in 1968 came with more possibilities - the 2 door cars could have either the Trico or Anco 15", same as used for the '68 A-bodies. Whereas the 4 doors and wagons could have a yet different wiper (maybe a 16"?)
Anco had several names for the push button wipers including 'red dot'.
I've seen posted (I think in the FABO thead) that some factory Anco push buttons were black and rectangular. They work the same.
Trico called their version of the system Latch Pin, hence LP series refills seem to be for the Anco push button blades.
edit: The Anco 19 series linked in the first post is too narrow. The U-15 is much closer to correct width, but would need to try one to know if that cross section will actually fit.
Below is from Anco's 2014 catalog:
