Indy 4.84" Bore Space block question?
#2276200
03/25/17 10:13 PM
03/25/17 10:13 PM
Posts: 6,136 Melbourne , Australia
LA360
Excuse my ignorance, I've had no experience with the 4.84" bore space stuff.
What crank goes in to these blocks, is it a 4.8" space crank with the difference taken up in the side clearance on the piston end? Or a 4.84" specific bore crank.
I wasn't sure when they designed these blocks if the main bearing saddles have been moved slightly or they've just moved the bores around.
Thanks in advance
Alan Jones
Re: Indy 4.84" Bore Space block question?
[Re: LA360]
#2276324
03/26/17 04:22 AM
03/26/17 04:22 AM
Posts: 275 brisbane,australia
coletrickle
brisbane,australia
Hey Allan are you going to be needing a 4.84 block?
[Re: sasquatch]
#2276331
03/26/17 05:02 AM
03/26/17 05:02 AM
LA360
The only cranks I have ever tried were the 5 inch stroke Callies. Indy starts the boring in the back and by the time you get to the front journal on the crank you have zero side clearance. As in cut the rods and start playing around with the bearings. If that 5 inch crank is "special" somehow I cannot find it as far as the rest of the block goes. The clearance just "stacks" back to front as best I can tell. Fun fun fun.... I suspected that was the case, I would have thought the difference would have been split from the centre cylinders, the 0.020" either side on 3 & 5, and the extra 0.040" coming out of 1 & 8. Really sounds like an engine you'd look at piston guided rods in
Alan Jones
[Re: LA360]
#2276384
03/26/17 11:10 AM
03/26/17 11:10 AM
Posts: 970 Farmington Hills, Mich
Chuck@Best_Machine
They use the same crank as the 4.800 block, the main saddles are in stock position. The center 2 bores are moved .020 and the outer bores are moved .060 from the centerline of # 3 main. You can use a Chevy 2.200 rod and in most cases there isn't any problem when using a full round skirt design but if your using a inboard pin boss or box style piston we go with the .927 pin and a narrower pin end on a aluminum rod.
[Re: Chuck@Best_Machine]
#2276387
03/26/17 11:14 AM
03/26/17 11:14 AM
Posts: 1,965 Apollo, PA.
B1MAXX
Apollo, PA.
They use the same crank as the 4.800 block, the main saddles are in stock position. The center 2 bores are moved .020 and the outer bores are moved .060 from the centerline of # 3 main. You can use a Chevy 2.200 rod and in most cases there isn't any problem when using a full round skirt design but if your using a inboard pin boss or box style piston we go with the .927 pin and a narrower pin end on a aluminum rod. I was thinking about an old b1 pro stock stuff... I could be wrong there too. Was it called a phoenix or something. I'm probably getting of topic, sorry.
[Re: B1MAXX]
#2276685
03/26/17 07:16 PM
03/26/17 07:16 PM
LA360
You are correct, the block used with the B1-TS heads was the Phoenix block. They weren't a deep skirt blockand featured a splayed 4-bolt cap.
Thanks for the replies, with all the talk about the Goodwin 600-13 heads, I was curious about it all.
Alan Jones
[Re: LA360]
#2277691
03/28/17 01:57 PM
03/28/17 01:57 PM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
Donovan has a block as well. Seen a few TS versions with one.
