Page 2 of 3 1 2 3
Re: Raceday story with a not so happy ending [Re: pittsburghracer] #2273230
03/20/17 08:25 PM
03/20/17 08:25 PM
Locomotion Offline
Locomotion  Offline
frown Yuck! That hurts just looking at it. Good luck on getting it back out while the kid is hot.
Re: Raceday story with a not so happy ending [Re: Al_Alguire] #2273233
03/20/17 08:30 PM
03/20/17 08:30 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I am a little fuzzy about the translation of the last sentence or so....
"After this he tells me he ripped the throttle twice to back into his opponent and went to put it in neutral and it just shut off. So likely went book then.."
Re: Raceday story with a not so happy ending [Re: Dragula] #2273253
03/20/17 09:07 PM
03/20/17 09:07 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
Man I hate seeing and hearing about this stuff. It does happen though. I'm sure the next engine will be even better.
Re: Raceday story with a not so happy ending [Re: Al_Alguire] #2273268
03/20/17 09:36 PM
03/20/17 09:36 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Probably meant , So likely went BOOM then. Just my take on it .
Re: Raceday story with a not so happy ending [Re: rowin4] #2273299
03/20/17 10:06 PM
03/20/17 10:06 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Man that sucks...hope you guys get it up and running soon the season is Young...
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Raceday story with a not so happy ending [Re: Al_Alguire] #2273324
03/20/17 10:36 PM
03/20/17 10:36 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Sorry to see that Al, that kind of stuff is always a setback for sure. Good luck with it.
Re: Raceday story with a not so happy ending [Re: ProSport] #2273357
03/20/17 11:27 PM
03/20/17 11:27 PM
Casper, WY
W
Wax Offline
Wax  Offline
W
Casper, WY
Hate to see that Al. A little off the main subject but how is your new project going? Just curious. Thanks
Re: Raceday story with a not so happy ending [Re: Al_Alguire] #2273413
03/21/17 12:46 AM
03/21/17 12:46 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
From Facebook
500 Inch B1 Engine
$8,500
Grantsville, MD (21536)
500 inch B1 headed big block complete from carb to pan. B block 230 casting, B1 originals ported, T&D rockers, Comp roller cam and lifters, BME aluminum rods, Mopar 4.15 crank, Ross pistons, 12.5 to 1 compression, 1150 King Demon. This will come complete oil system and everything. There are 12 1/8 mile passes on this engine and about 30 street miles. $8500.00 obo. 301-707-5852
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Raceday story with a not so happy ending [Re: Al_Alguire] #2273415
03/21/17 12:49 AM
03/21/17 12:49 AM
Central So California
Broom Hilda Offline
Broom Hilda  Offline
Al,
I have 2 440 blocks, 3 stock cranks, 8 Probe pistons out of my car, & 6 h-beam rods (Scat I think). Let me know if any of this would help. Just loading it up for the swap meet at end of next month. Also have a dragster style pan if yours is bad.
Ron
Re: Raceday story with a not so happy ending [Re: Al_Alguire] #2273427
03/21/17 01:03 AM
03/21/17 01:03 AM
Btween a rock and a hard place
moparlulu Offline
moparlulu  Offline
Originally Posted By Al_Alguire
Originally Posted By Triple Threat
frown
Been there, no fun. Time to toss the 511 in.
I sold the 511 to a guy in NorCal that needed an engine as this one just needed to finish out the year and has been doing fine.
The cylinder wall let go, surprised really it hydrauliced the cylinder. Never actually seen one do this before. Just dropped the heads off at a local shop, the guy he beat in RD 1. Told him wish you have won that round as we would have loaded up and likely found the issues next fire up when the cylinder filled with water. Then would have just been a block. So to answer the head question it bent both valves in that cylinder as well as banged up the head a bit. No real big damage will get fixed and be good to go. All the damage to block and heads were limited to #6. Still spun like butter once we removed the loose chunk of piston. All the bearings looked new as well. Need to scramble now to find something for the kid. I don't have anything except a couple of aluminum B1's to put in it and not ready to do that yet as they will likely be under the 7.50 mark.
Will post a pic up of a piston later. They are no use to me at this point.
Greg I had a good low deck built but see above. Someone was in need and I let it go. I have a couple 400 blocks left but not sure I wanna put a lot of money into one to finish the year. We will have an Indy/B1 for it next year just need to order pistons for it, a cam and get some good rockers for it. Then assemble it and get it in the car. He is on a tight budget and I am done paying for everything.
. Would a 750 cfm carb slow it down enuff?
Re: Raceday story with a not so happy ending [Re: Al_Alguire] #2273439
03/21/17 01:15 AM
03/21/17 01:15 AM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
looks like the valve whacked the piston pretty good too
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Raceday story with a not so happy ending [Re: Al_Alguire] #2273451
03/21/17 01:31 AM
03/21/17 01:31 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
YUK! Sorry to see this Al. I hate these sort of posts. Best of luck getting a new bullet together.
Re: Raceday story with a not so happy ending [Re: Al_Alguire] #2273457
03/21/17 01:42 AM
03/21/17 01:42 AM
Las Vegas
Al_Alguire Offline OP
Las Vegas
Exhaust valve hit yes and is bent as is the intake valve and some shrapnel damage to the chamber but nothing big, easy fix.
Yes to clarify we think that's when it went boom. As it shut off then.
Broom Hilda we are still weighing options. Appreciate the info and we may be getting ahold of you. Kind of looking for a shortblock, just something solid and decent parts. May have one located already. Everything else from the engine is fine except #6. Crank has no damage it appears, heck even that rod bearing in that hole was fine. So if we could locate someone with a block crank and rods and pistons we are set.
Pittsburgh, we have a B1 engine sitting here that is a new build with only dyno time. Just not sure I want to go there now. We also have one we have been collecting parts for as he has monies. It was to be next years engine for him. Just a basic 850ish HP aluminum block deal. Just needs pistons, cam and a few other small things to get machine work done. Heads are done, block is waiting final hone.
Wax, Other project is basically done. We have a date next week with Gary Hansen to get the air pan built for the scoop and some other little odds and ends finished up. Then it is pretty much ready to go, just have to make an engine decision. Might pull it back out and change some stuff and fix a couple little issues. One reason I don't want to put the other Kb/B1 deal I have in the dragster as I am thinking of putting it in the Stratus for now while we address some issues.
Myron yep want to get him back in the car sooner than later. He is still learning and don't want that to stop. He is not running points here this year as his older sister has her wedding on the ET finals date. But if he were he would be top 10 right now, I believe tied for 5th even not going anymore rounds Saturday due to the failure.
Re: Raceday story with a not so happy ending [Re: Al_Alguire] #2273471
03/21/17 02:07 AM
03/21/17 02:07 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Big boom bummer. down
Re: Raceday story with a not so happy ending [Re: Al_Alguire] #2273486
03/21/17 03:04 AM
03/21/17 03:04 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Hey Al what RPM you guys spinning to ? Sorry to see the mess mate.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Raceday story with a not so happy ending [Re: Al_Alguire] #2273498
03/21/17 04:41 AM
03/21/17 04:41 AM
Al, are those piston Hyper silicone cast pistons? If not, I never seen a forged piston discentrigrate (SP) like yours did confused I have seen cast pistons do that shruggy
I believe the piston failed first allowing the wrist pin to destroy the cylinder wall and block shruggy
Re: Raceday story with a not so happy ending [Re: Al_Alguire] #2273643
03/21/17 01:25 PM
03/21/17 01:25 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Never like to see this Al but w/your connections, you guys will be up and running soon I believe...........Good luck man............ luck
Re: Raceday story with a not so happy ending [Re: Al_Alguire] #2273660
03/21/17 01:50 PM
03/21/17 01:50 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
Ouch, that sucks! I'm sure you'll get it back up and running soon!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Raceday story with a not so happy ending [Re: Al_Alguire] #2273671
03/21/17 02:07 PM
03/21/17 02:07 PM
Las Vegas
Las Vegas
Cab it is a forged Ross piston.
Dom we are still looking at options for now.
Yeah sucks for sure. Was hoping to get 5-6 more races out of this thing this year and move on. Now my poor truck has no engine.
Re: Raceday story with a not so happy ending [Re: Al_Alguire] #2273689
03/21/17 02:35 PM
03/21/17 02:35 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Al,
What about the indy deal you got from me?
Page 2 of 3 1 2 3
