Re: Real world weight loss program and it` cost..........
[Re: Thumperdart]
#2274314
03/22/17 04:28 PM
03/22/17 04:28 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Ok,,,you guys told me how to lighten the stock column and I really dig how Doug used the old shifter hole. While I have the column out{when I do it,,} I want to eliminate the clutch pedal that's been hanging out for 35 years doing nothing.Do I just remove it and put a spacer where it is,,,,,,or does it require a different assembly and I sell the 2 pedal set-up?? Dropped the bare block in to peek n see how it will work out.My existing header flanges can be modified to work.Lowering the block down where it belongs now gives me almost 2 inches from the back of the r/s vc,,,,,thinking about moving the engine back,,,,,,,,,, It also appears that 2 tubes by the starter & steering box will need some relocation. Chippin away
[Re: hemi-itis]
#2274350
03/22/17 05:20 PM
03/22/17 05:20 PM
Posts: 5,112 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Hemi-itis...there are a few subtle differences in the pedal assemblies for 62-5 B Bodies. I have an auto set-up out of a 65 if you need one. You may want to make sure everything will work and I do have to pull it out yet. I put 4 speed pedals from a 63 Dodge 330 into my 65 Dodge Coronet (originally auto) with no issues except drilling the extra holes. When I talked to Jamie from Passion Performance at Carlisle he said that 63 and 65 were different. I didn't notice the difference... He may have meant 4 speed only...seems I remember a discussion a while back about some having roller bearings and others not... It's worth more to sell it and replace it with auto but I think you can just change the pedal and use an automatic pin or bolt in the top and retain the same assembly minus the two pedals... Your call.. As far as the rest of your progress...I got a buddy that does chassis fab and such...His motto is "When in doubt...cut it out"...
...FAFO...
[Re: hemi-itis]
#2274371
03/22/17 06:01 PM
03/22/17 06:01 PM
Posts: 21 South Louisiana
DBCooper
South Louisiana
Heard he had blown a window into the original block one night racing on the 110. Had it welded back up, but installed a replacement block to which it was probably what you saw and heard by then. It was a high 10 piece with steel wheels and all. I believe the piece was worked, assembled and tuned by another well known character from those days and nights by the name of "RED". Pete never offered it to me for sale but was well aware of my car as well. I guess both pieces were rather active at the same time complimenting each other. By the way, I created a mural of that A-990 on the side wall of his parts shop out there somewhere on the Island, but can't remember what township. Hemi-itis might know. He was very happy with it. He asked me how I knew all the lines, reflective points, nooks and crannies of such a car, I looked at him with a stare of REALLY! LoL. Pudlin Auto Parts was on Carman Ave in Westbury.I can close my eyes and see that Mural.Pete was proud of that. It's Reds fault I went to work at that repair shop in Great Neck.That's a different book yet to be written. I met Pete when I was on my GS1150 that was a 1229cc with a hidden bottle under the seat.I was king of Hempstead Turnpk from 86 to 89.My 63 had a blowed up wedge in it at the time.Pete sold me a 66 hemi on weekly payments.Boy,,,alotta history being stirred BTW,here is Reds currant car with his brother Myron on the fender. Richard Kay is in this crazy circle as well! Hello ! Can I get some info on this car ? I a,m not sure why the pics don't show. I am referring to the 62 Dart. Weight ? What does it run ? Is it a real Max Wedge car ? Can I get more pics ?
[Re: Thumperdart]
#2274617
03/23/17 01:33 AM
03/23/17 01:33 AM
hemi-itis
Looks like I can remove the pedal and might need a spacer to replace it.
[Re: hemi-itis]
#2276499
03/26/17 02:27 PM
03/26/17 02:27 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
this can go in the direction of slightly alter wheelbase!
Hell Hath No Fury Like Mine
[Re: Thumperdart]
#2276617
03/26/17 05:09 PM
03/26/17 05:09 PM
Posts: 1,894 Spahn Ranch
RMCHRGR
Spahn Ranch
Al, you ever going to put front support bars in that thing? Maybe consider doing that before cutting up the car to get the mid plate to work. If that is in fact what you're doing...
Front supports might allow you to get rid of some of the inner fender (more room, less weight) and would really help to stiffen things up.
Just a thought, not trying to spend your money.
'71 Duster '72 Challenger '17 Ram 1500
[Re: Thumperdart]
#2276645
03/26/17 06:02 PM
03/26/17 06:02 PM
RMCHRGR
Spahn Ranch
Now you're talkin'. Whew.
You going to lose the rest of the inner fenders? Not much left between the firewall and shock tower to begin with.
You could hang some of your support junk off the bars.
[Re: hemi-itis]
#2277165
03/27/17 02:34 PM
03/27/17 02:34 PM
Posts: 1,453 N.W. INDIANA
moparjohn
N.W. INDIANA
I don't know if Mopar big block starters and their weight has been discussed here? This past week I weighed the 3 smaller newer style starters. I have 2 that are about an inch shorter than the third and they both weigh in at 8 LBS 4 OZ. The longer one is over 10 LBS! So what I want to know is there any out there for big blocks that weigh less? If so what is the part number? One of the part numbers I have at 8 LBS 4 OZ is R3005984 and is to work with any engine even the V 10 is listed! Thanks!
[Re: moparjohn]
#2277222
03/27/17 04:11 PM
03/27/17 04:11 PM
fullmetaljacket
As far as it's known, there are three Denso type lightweight starters that have been introduced to the market over the last 15-18 years. For decades the standard infamously sounding wind starters were the only norm aside from unpredictable and non stock looking aftermarket starters. These factory starters dating back to the 60's or earlier weighed a ton usually at 16-18 Lbs. My forehead is still recovering from the knocks. LOL. The first lightweight types that I came across were the 90's van versions that weighed in the hood of 10-11 Lbs. After those came the 8-9 pounders and then the current one that is at a high 7's in weight. Heat shields have been removed and the winding housings are a tad smaller along with the snout and its bosses IIRC.
