Stealth or ProMaxx on 400-450 cube engine #2271728
03/18/17 12:57 PM
03/18/17 12:57 PM
Granbury TX
Prochargedmopar Offline OP
Granbury TX
Being price is within $100 of each other.
Considering a turbo will be used in this application are these heads about the same?
Which one has more potential later on if porting is done?
440source has been around a long time and I'm familiar with the name. (advertising works)
But the ProMaxx heads have the bling bling sound and seem "new".
"Old" member Registered: Sep 2001
Lost my credentials, I'm Back!! LOL
71 Ply Satellite Procharged
73 Dodge Dart Swinger
73 Ford F-100 390/Sniper efi/back to carb
01 Town and Country Limited
08 Dodge 2500 6.7 5" Deleted
02 Mercedes C230K
19 Camry
Re: Stealth or ProMaxx on 400-450 cube engine [Re: Prochargedmopar] #2271739
03/18/17 01:04 PM
03/18/17 01:04 PM
Maryland
twayne24365 Offline
twayne24365  Offline
Maryland
dad has a set of the CNC ported stealth heads. quality was very nice and they have a pretty thick deck. I'm sure they would handle some boost
Re: Stealth or ProMaxx on 400-450 cube engine [Re: twayne24365] #2271741
03/18/17 01:11 PM
03/18/17 01:11 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I have them as well. They work pretty good on a budget.
'63 Dodge 330
11.19 @ 121 mph
Re: Stealth or ProMaxx on 400-450 cube engine [Re: Prochargedmopar] #2271811
03/18/17 03:28 PM
03/18/17 03:28 PM
Shannonville, Ont
Blown 68 R/T Offline
Shannonville, Ont
I have a set of Sidewinders from Todd Marsh, they are on my 440 with an F2 Procharger. Runs 15lbs boost no problem. Had Larry Smith do some porting on them as well.
Re: Stealth or ProMaxx on 400-450 cube engine [Re: Blown 68 R/T] #2271982
03/18/17 08:22 PM
03/18/17 08:22 PM
Granbury TX
Granbury TX
Are the sidewinders in the same price and as cast flow range?
02 Mercedes C230K
19 Camry
