Stealth or ProMaxx on 400-450 cube engine
#2271728
03/18/17 12:57 PM
03/18/17 12:57 PM
Posts: 274 Granbury TX
Prochargedmopar
Granbury TX
Being price is within $100 of each other.
Considering a turbo will be used in this application are these heads about the same?
Which one has more potential later on if porting is done?
440source has been around a long time and I'm familiar with the name. (advertising works) But the ProMaxx heads have the bling bling sound and seem "new".
"Old" member Registered: Sep 2001 Lost my credentials, I'm Back!! LOL 71 Ply Satellite Procharged 73 Dodge Dart Swinger 73 Ford F-100 390/Sniper efi/back to carb 01 Town and Country Limited 08 Dodge 2500 6.7 5" Deleted 02 Mercedes C230K 19 Camry
Re: Stealth or ProMaxx on 400-450 cube engine
[Re: twayne24365]
#2271741
03/18/17 01:11 PM
03/18/17 01:11 PM
Posts: 4,691 Wichita
GY3
Wichita
dad has a set of the CNC ported stealth heads. quality was very nice and they have a pretty thick deck. I'm sure they would handle some boost I have them as well. They work pretty good on a budget.
[Re: Blown 68 R/T]
#2271982
03/18/17 08:22 PM
03/18/17 08:22 PM
Prochargedmopar
Granbury TX
I have a set of Sidewinders from Todd Marsh, they are on my 440 with an F2 Procharger. Runs 15lbs boost no problem. Had Larry Smith do some porting on them as well. Are the sidewinders in the same price and as cast flow range?
