Predator heads
#2268866
03/13/17 08:00 PM
03/13/17 08:00 PM
Posts: 98 Spokane Wa
slick526
Spokane Wa
Has anyone out there put a predator headed RB engine in a stock engine bay? I have a 63 dodge b body. Would there be enough room for the headers without having to cut the fender wells????
Qwik Brick
Re: Predator heads
[Re: slick526]
#2269332
03/14/17 01:03 PM
03/14/17 01:03 PM
Posts: 19,664 Las Vegas
Al_Alguire
Las Vegas
Darren Tedder(DTHEMI) has one in an old B Body, believe it is a 65. Blasko has one in his Dart and Eddie Miller had one in a Duster. We had a 99 Hemi in a 68 Barracuda with inner fenders etc I see no reason a Predator cannot be done.
Re: Predator heads
[Re: slick526]
#2269553
03/14/17 07:20 PM
03/14/17 07:20 PM
Posts: 200 AB
Efidart
AB
Yes in a B body they will work, there is not a production header for them but there is definitely enough room without cutting to make a custom set.
2 1/8" minimum tube diameter to start 2 1/4" is probably better suited. In an A body... unless you are a contortionist there isn't room without cutting.
TT Predator headed 572 7 Second Street Car. Fastest Mopar Drag Week 2015 Fastest Mopar & Dodge Drag Week 2017 Pro Street Power Adder Champion Drag Week 2017
Re: Predator heads
[Re: slick526]
#2269955
03/15/17 12:30 PM
03/15/17 12:30 PM
Posts: 200 AB
Efidart
AB
The valve train is bulletproof really..
Every rocker is the same and with pushrod oiling it is almost OEM like reliability.
Re: Predator heads
[Re: Efidart]
#2271147
03/17/17 12:53 PM
03/17/17 12:53 PM
slick526
Spokane Wa
Thanks for the info. Those heads would be cool to try. Its a toss up between the Indy -13 and the Predators. Anyone want to chime in pros or cons of which to pick???
Qwik Brick
Re: Predator heads
[Re: slick526]
#2271245
03/17/17 03:50 PM
03/17/17 03:50 PM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
All I will say is, look at the flow numbers and rocker geometry of the 600-13's VS the Predators. I had some B1/MC heads on a 572 engine I had. The combo was a 16.3-1 comp., .890 I .810 E, 112 LC Duration 288-298@50*, maxed out at a true 449 I flow on a 4.500 fixture. It ran 7.50's and 60's at 172-174 MPH in 4500 actual elevation but commonly 5500-8500 Corrected and easy to tune converter and 60' wise. My Predator headed 572 using the same block, crank, etc. had a like cam, 14.5-1 comp. In the same air, and once I started to get the combo and converter figured out (much looser) it ran mid 50's and high 40's at 175-177 MPH. I am sure many here will dispute this but, the predator stuff makes more power and is better that the B1/MC stuff. IMO and I've never done an Indy 600-13 headed engine, is the B1/MC head is better than the 600-13 based on the N/A engines I've seen running them. The wedge head is easier to tune though as there aren't many here that know how to tune the Predator deal, so there is more trial and error. Al Alguire, Boat racer (Tony), and I am sure a few others here can help. Indy was absolutely the worst and always has been, customer service I have come across. At least with the B1 stuff there are people to ask, and Scott Koffel can give advice and does. I would never go back to a wedge head on a Mopar though. Also, don't believe the Indy garb about 1350HP N/A. JMO
Re: Predator heads
[Re: slick526]
#2271378
03/17/17 08:05 PM
03/17/17 08:05 PM
KOS
i think the "new" 600-13 will give em a run for there money...maybe even equal or better.the only plus is the pred still uses std bore spacing block.
Re: Predator heads
[Re: KOS]
#2271410
03/17/17 09:00 PM
03/17/17 09:00 PM
Posts: 4,457 Washington
madscientist
Washington
i think the "new" 600-13 will give em a run for there money...maybe even equal or better.the only plus is the pred still uses std bore spacing block. If it was just about flow, than maybe the 600-13 would have some chance with the Predator. It isn't just about flow.
Re: Predator heads
[Re: madscientist]
#2271441
03/17/17 09:52 PM
03/17/17 09:52 PM
KOS
i think the "new" 600-13 will give em a run for there money...maybe even equal or better.the only plus is the pred still uses std bore spacing block. If it was just about flow, than maybe the 600-13 would have some chance with the Predator. It isn't just about flow. yes i know .....i know of couple guys making some serious steam with those heads with track times to prove.so its not just about flow....
Re: Predator heads
[Re: camastomcat]
#2271488
03/17/17 11:24 PM
03/17/17 11:24 PM
KOS
It doesn't help that the 4.800 crankshaft has to offset rods to piston pins to fit a 4.840 block either. At least that's the way I understand it. And the only head and block that work with that combo is the 600-13 and 4.840 Indy......well I'll be nice and say stuff. i never realized it got even more complex not just the exclusive block deal.....pred looks like the smarter bet.
Re: Predator heads
[Re: slick526]
#2271748
03/18/17 12:22 PM
03/18/17 12:22 PM
Posts: 200 AB
Efidart
AB
If BAE made water stuff...
Head gasket reliability being a symmetrical port design helps on the predators too.
Re: Predator heads
[Re: Efidart]
#2271879
03/18/17 04:40 PM
03/18/17 04:40 PM
camastomcat
Salt Lake City
Head gasket reliability being a symmetrical port design helps on the predators too. That was the main reason I went that way.
Re: Predator heads
[Re: Efidart]
#2272061
03/18/17 10:31 PM
03/18/17 10:31 PM
Posts: 1,050 San Jose Ca.
boatracer572
San Jose Ca.
Head gasket reliability being a symmetrical port design helps on the predators too. BAE will make u anything you want,( forged semi water block) but your going to pay$$$$$ for it
Re: Predator heads
[Re: Charga]
#2272336
03/19/17 01:00 PM
03/19/17 01:00 PM
boatracer572
San Jose Ca.
Very tough to find used, once people run them they very seldom come off there motors in usable comdition... easier to find then new/bare
