Page 1 of 7 1 2 3 4 5 6 7
CLEAR THE AIR ON SB HEAD CHOICE #2270909
03/17/17 12:19 AM
03/17/17 12:19 AM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
There has been a few posts on Sb heads. I just went through them. Personal choices, rumors and all out race suggestions. I need a set of SB heads to move my 3300 lbs M body to consistent muffled 12.00's to run a 12.50 index this year. Short block - 360, .030, 520/540 w/ 290 duration, 10.5 compression with a 68cc combustion chamber and a 4.10 rear. Waiting on the final combo before I select a converter. All I need is to select a pair of heads. I have a set of 308's that need a total rebuild, but when you calculate the cost of a rebuild a new set, new iron /aluminum, is about the same. Any thoughts? THX
Re: CLEAR THE AIR ON SB HEAD CHOICE [Re: A/MP] #2270915
03/17/17 12:37 AM
03/17/17 12:37 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
ProMaxx
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: CLEAR THE AIR ON SB HEAD CHOICE [Re: A/MP] #2270919
03/17/17 12:45 AM
03/17/17 12:45 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I agree.. the cost of rebuilding vs new your
better off with new.. I'm running W-2s which are
iron and weight more(about 40# per set) but they
can be made to flow well.. I have mine at about
312 cfm(might be 315 now)but they are about max now..
I have a set of W-5s but an having a issue with them
at the present time.. but I will get them right.. they
flow 319 at 600 lift.. both take off set rockers.. but
the alum W-5s are 40#lighter
wave
Re: CLEAR THE AIR ON SB HEAD CHOICE [Re: A/MP] #2270923
03/17/17 01:03 AM
03/17/17 01:03 AM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Is there a ProMaxx Magnum equivalent?
Re: CLEAR THE AIR ON SB HEAD CHOICE [Re: A990] #2270927
03/17/17 01:13 AM
03/17/17 01:13 AM
PA.
"Little"John
"Little"John
PA.
Not that I know of but it would be worth a call. Man did they jump up in price.
http://www.jegs.com/p/ProMaxx-Performanc...451148/10002/-1
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: CLEAR THE AIR ON SB HEAD CHOICE [Re: A/MP] #2270933
03/17/17 01:29 AM
03/17/17 01:29 AM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Call Rod bloomer he has a very nice ported heads for someone looking to up grade over stock and use all stock rocker gear no high dollar rocker gear needed
Re: CLEAR THE AIR ON SB HEAD CHOICE [Re: A/MP] #2270946
03/17/17 01:56 AM
03/17/17 01:56 AM
Az
Crizila Offline
Crizila  Offline
Az
Mid 12's, buy a set of reconditioned Indy heads for $500. They come with new Stainless 2.02 / 1.60 valves, bronze guides, springs, seals, locks, retainers. Take them apart, pocket port and gasket match them, and that should put you in the mid 12 range on the cheap.
Fastest 300
Re: CLEAR THE AIR ON SB HEAD CHOICE [Re: A/MP] #2271053
03/17/17 10:55 AM
03/17/17 10:55 AM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
On the Pro Max, what do you guys do for a heat crossover on a street/strip machine? I also looked at those Aero heads. Some rumblings about fit, finish and parts used by Indy.
Re: CLEAR THE AIR ON SB HEAD CHOICE [Re: A/MP] #2271057
03/17/17 11:07 AM
03/17/17 11:07 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Rod Bloomer's heads are the best value for the money. Great flowing, lost cost and much better quality then the others. Two versions are available, factory non offset rocker and off set rockers.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: CLEAR THE AIR ON SB HEAD CHOICE [Re: 1967dartgt] #2271097
03/17/17 12:23 PM
03/17/17 12:23 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Originally Posted By 1967dartgt
Rod Bloomer's heads are the best value for the money. Great flowing, lost cost and money ch better quality then the others. Two versions are available, factory non offset rocker and off set rockers.
Agreed. Those are super nice pieces. And Rod supports the hobby
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: CLEAR THE AIR ON SB HEAD CHOICE [Re: A/MP] #2271137
03/17/17 01:40 PM
03/17/17 01:40 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Rods heads indeed look like nice pieces, and I applaud him for all the time and effort it took for him to be able to bring these to market.
However....... That doesn't mean they are going to be the best choice for every build.
I think they are overkill for a stock stroke 360 in a 12 second car.
If I were making the decisions, it would get Edelbrock rpm heads.
Re: CLEAR THE AIR ON SB HEAD CHOICE [Re: 1967dartgt] #2271189
03/17/17 03:00 PM
03/17/17 03:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Does any one have a web site for Rod Bloomer heads
thanks
wave
Re: CLEAR THE AIR ON SB HEAD CHOICE [Re: MR_P_BODY] #2271196
03/17/17 03:10 PM
03/17/17 03:10 PM
PA.
"Little"John
"Little"John
PA.
thanks
wave
https://board.moparts.org/ubbthreads/ubbt...tml#Post2110101
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: CLEAR THE AIR ON SB HEAD CHOICE [Re: A/MP] #2271524
03/18/17 01:37 AM
03/18/17 01:37 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Low 12s in a 3300 lb car? That sounds easy with a set of nearly stock magnum heads. As cast they flow 200, a little work if you have time and you're at 220-230. Or, a set of EQs that are 220-ish as cast. Or aluminum eddy heads at 240-250.
Cheap n easy.
**Photobucket sucks**
Re: CLEAR THE AIR ON SB HEAD CHOICE [Re: Crizila] #2271549
03/18/17 02:19 AM
03/18/17 02:19 AM
MR_P_BODY Offline
MR_P_BODY  Offline
On these... where do you buy reconditioned
Indy heads.. I wouldnt mind finding a set
of 360-1s at a reasonable price
wave
Re: CLEAR THE AIR ON SB HEAD CHOICE [Re: MR_P_BODY] #2271560
03/18/17 02:52 AM
03/18/17 02:52 AM
PA.
"Little"John
"Little"John
PA.
Thinking may next two small block head purchases will be a set of W7 heads for a 48 degree block I bought since I got Jessel rockers and intake with it and a set of edelbrock Victor heads for my R3 block in my black duster to see if I can get it in the 8's
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: CLEAR THE AIR ON SB HEAD CHOICE [Re: pittsburghracer] #2271561
03/18/17 02:53 AM
03/18/17 02:53 AM
PA.
"Little"John
"Little"John
PA.
In your case stay simple and cheap to run the bracket you are aiming for
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: CLEAR THE AIR ON SB HEAD CHOICE [Re: A/MP] #2271634
03/18/17 10:16 AM
03/18/17 10:16 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Edelbrock gets my vote as well. I went 11.50s with out of the box edelbrocks on a solid roller 11:1 360@3500lbs. I bought the heads, took them to the machine shop and had the valve job and guide tightness checked. Then I slapped on some springs to go with my cam and went racing. I later had Shady Dell to his stage II port job and install 2.05 intake valves. It went a best of 11.16@119.5. I just sold them to a member here, I almost didn't want to let them go they served me so well haha, the money is going to finish my Dana 60 and convert my tunnel ram to EFI though haha.
68 Barracuda Formula S 340
Re: CLEAR THE AIR ON SB HEAD CHOICE [Re: A/MP] #2271705
03/18/17 12:31 PM
03/18/17 12:31 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Shortly you will see a "Build me a motor" thread around them too. boogie
Re: CLEAR THE AIR ON SB HEAD CHOICE [Re: A/MP] #2272117
03/19/17 01:26 AM
03/19/17 01:26 AM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Since most of these aluminum heads have no heat cross over, is there a tip to getting the intake warm enough on cold winter days?
