Re: CLEAR THE AIR ON SB HEAD CHOICE
[Re: A/MP]
#2270919
03/17/17 12:45 AM
03/17/17 12:45 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I agree.. the cost of rebuilding vs new your better off with new.. I'm running W-2s which are iron and weight more(about 40# per set) but they can be made to flow well.. I have mine at about 312 cfm(might be 315 now)but they are about max now.. I have a set of W-5s but an having a issue with them at the present time.. but I will get them right.. they flow 319 at 600 lift.. both take off set rockers.. but the alum W-5s are 40#lighter
[Re: A990]
#2270927
03/17/17 01:13 AM
03/17/17 01:13 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Is there a ProMaxx Magnum equivalent? Not that I know of but it would be worth a call. Man did they jump up in price. http://www.jegs.com/p/ProMaxx-Performanc...451148/10002/-1
[Re: A/MP]
#2270933
03/17/17 01:29 AM
03/17/17 01:29 AM
Posts: 1,563 New Smyrna Beach FL
scottb
New Smyrna Beach FL
Call Rod bloomer he has a very nice ported heads for someone looking to up grade over stock and use all stock rocker gear no high dollar rocker gear needed
[Re: A/MP]
#2270946
03/17/17 01:56 AM
03/17/17 01:56 AM
Posts: 7,506 Az
Crizila
Az
Mid 12's, buy a set of reconditioned Indy heads for $500. They come with new Stainless 2.02 / 1.60 valves, bronze guides, springs, seals, locks, retainers. Take them apart, pocket port and gasket match them, and that should put you in the mid 12 range on the cheap.
Fastest 300
[Re: A/MP]
#2271057
03/17/17 11:07 AM
03/17/17 11:07 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Rod Bloomer's heads are the best value for the money. Great flowing, lost cost and much better quality then the others. Two versions are available, factory non offset rocker and off set rockers.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#2271097
03/17/17 12:23 PM
03/17/17 12:23 PM
Posts: 11,728 Portage,michigan
B3422W5
Portage,michigan
Rod Bloomer's heads are the best value for the money. Great flowing, lost cost and money ch better quality then the others. Two versions are available, factory non offset rocker and off set rockers. Agreed. Those are super nice pieces. And Rod supports the hobby
[Re: A/MP]
#2271137
03/17/17 01:40 PM
03/17/17 01:40 PM
fast68plymouth
So. Burlington, Vt.
Rods heads indeed look like nice pieces, and I applaud him for all the time and effort it took for him to be able to bring these to market.
However....... That doesn't mean they are going to be the best choice for every build. I think they are overkill for a stock stroke 360 in a 12 second car.
If I were making the decisions, it would get Edelbrock rpm heads.
[Re: 1967dartgt]
#2271189
03/17/17 03:00 PM
03/17/17 03:00 PM
MR_P_BODY
Rod Bloomer's heads are the best value for the money. Great flowing, lost cost and money ch better quality then the others. Two versions are available, factory non offset rocker and off set rockers. Does any one have a web site for Rod Bloomer heads thanks ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#2271196
03/17/17 03:10 PM
03/17/17 03:10 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Rod Bloomer's heads are the best value for the money. Great flowing, lost cost and money ch better quality then the others. Two versions are available, factory non offset rocker and off set rockers. Does any one have a web site for Rod Bloomer heads thanks https://board.moparts.org/ubbthreads/ubbt...tml#Post2110101
[Re: A/MP]
#2271524
03/18/17 01:37 AM
03/18/17 01:37 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Low 12s in a 3300 lb car? That sounds easy with a set of nearly stock magnum heads. As cast they flow 200, a little work if you have time and you're at 220-230. Or, a set of EQs that are 220-ish as cast. Or aluminum eddy heads at 240-250.
Cheap n easy.
**Photobucket sucks**
[Re: Crizila]
#2271549
03/18/17 02:19 AM
03/18/17 02:19 AM
MR_P_BODY
Mid 12's, buy a set of reconditioned Indy heads for $500. They come with new Stainless 2.02 / 1.60 valves, bronze guides, springs, seals, locks, retainers. Take them apart, pocket port and gasket match them, and that should put you in the mid 12 range on the cheap. On these... where do you buy reconditioned Indy heads.. I wouldnt mind finding a set of 360-1s at a reasonable price ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#2271560
03/18/17 02:52 AM
03/18/17 02:52 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Thinking may next two small block head purchases will be a set of W7 heads for a 48 degree block I bought since I got Jessel rockers and intake with it and a set of edelbrock Victor heads for my R3 block in my black duster to see if I can get it in the 8's
[Re: pittsburghracer]
#2271561
03/18/17 02:53 AM
03/18/17 02:53 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
In your case stay simple and cheap to run the bracket you are aiming for
[Re: A/MP]
#2271634
03/18/17 10:16 AM
03/18/17 10:16 AM
Posts: 8,037 Tulsa OK
Bad340fish
Tulsa OK
Edelbrock gets my vote as well. I went 11.50s with out of the box edelbrocks on a solid roller 11:1 360@3500lbs. I bought the heads, took them to the machine shop and had the valve job and guide tightness checked. Then I slapped on some springs to go with my cam and went racing. I later had Shady Dell to his stage II port job and install 2.05 intake valves. It went a best of 11.16@119.5. I just sold them to a member here, I almost didn't want to let them go they served me so well haha, the money is going to finish my Dana 60 and convert my tunnel ram to EFI though haha.
68 Barracuda Formula S 340
