Re: Transmission ID 727? BB or SB?
[Re: VegasCharger]
#2270253
03/15/17 10:36 PM
03/15/17 10:36 PM
Posts: 11,543 chicagoland,usa
buildanother
chicagoland,usa
B-RB. And don't forget to get that right side dowel pin installed back into block before install.
[Re: shocktrp]
#2270301
03/15/17 11:58 PM
03/15/17 11:58 PM
RapidRobert
Your Q has been answered but for future reference, a B/RB 727 will have (4) 1/4" dust cover mounting holes (SB has (2) 1/4" bolt holes) and facing the front of the trans a B/RB trans has a rounded face at the ~9 0'clock position (SB is kind of flat on that side). there is also a C to C dimention difference between the two top mounting bolt holes but I ain't sure what the dimentions are.
[Re: VegasCharger]
#2270338
03/16/17 12:44 AM
03/16/17 12:44 AM
Posts: 367 Akron, Ohio
VegasCharger
Akron, Ohio
Thanks to all who have replied. So it looks like I have a 1977 727 for a BB. Did Chrysler bog down the performance on their 727s as they did on their early HP motors? In other words are the mid to late 70s 727s perform the same as the early 70s 727s? Again thanks for all of the help thus far.
[Re: barracuda7199]
#2270379
03/16/17 02:24 AM
03/16/17 02:24 AM
RapidRobert
Even easier way to tell sb from bb is the dowel pin holes. Small block are straight across from each other. BB the starter side is always higher than the pass. Side. With that said which ones are the dowel holes? Easy the ones that are chamfered! Best one yet
[Re: VegasCharger]
#2270410
03/16/17 07:37 AM
03/16/17 07:37 AM
Posts: 138 central pa
darted1
central pa
also small block bells have a top center bolt hole big blocks dont.
ED M
[Re: darted1]
#2270426
03/16/17 10:06 AM
03/16/17 10:06 AM
Posts: 43,575 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
also small block bells have a top center bolt hole big blocks dont. THE easiest way to immediately tell them apart!
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#2270485
03/16/17 12:34 PM
03/16/17 12:34 PM
Posts: 280 GEORGIA
barracuda7199
GEORGIA
also small block bells have a top center bolt hole big blocks dont. THE easiest way to immediately tell them apart! I believe that is manual trans only guys.
[Re: VegasCharger]
#2270570
03/16/17 03:04 PM
03/16/17 03:04 PM
Posts: 25,849 Rio Linda, CA
John_Kunkel
Rio Linda, CA
IMO, the easiest way to ID BB or SB is by the converter dust cover bolt holes.
[Re: 6bblgt]
#2270610
03/16/17 04:20 PM
03/16/17 04:20 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
The 3/8" inch holes at 8 and 4 o'clock are for the strut bars on a small block
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Hot 340]
#2270845
03/16/17 10:45 PM
03/16/17 10:45 PM
RapidRobert
Dynamite tips, take your pick!
