Re: Nascar truck engine for street strip A body?? [Re: Scoober] #2268592
03/13/17 01:53 PM
03/13/17 01:53 PM
Sarasota, Fl
Scoober Offline OP
Scoober  Offline OP
Sarasota, Fl
Hey Guys,
Can someone give me the lowdown on attaching pics?? My geek friend isn't to sure what to do either. I am quite the novice with this stuff shruggy
THX All....
Re: Nascar truck engine for street strip A body?? [Re: Scoober] #2268639
03/13/17 03:02 PM
03/13/17 03:02 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
Originally Posted By Scoober
Hey Guys,
THX All....
I send mines to photobuck then use there link to post pictures on here..hopefully this helps
Re: Nascar truck engine for street strip A body?? [Re: Scoober] #2268650
03/13/17 03:15 PM
03/13/17 03:15 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
When you reply, below the text box you are typing in is a "switch to full reply screen" box. Click on that.
In the full reply screen, below the text box is "file manager" click on that.
Now hit the "browse" box. It should take you to your pics.
Select the pic, then click "add file"
Re: Nascar truck engine for street strip A body?? [Re: Scoober] #2268654
03/13/17 03:23 PM
03/13/17 03:23 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
https://board.moparts.org/ubbthreads/ubbt...tml#Post1799584
https://board.moparts.org/ubbthreads/ubbt...t-pictures.html
A couple of "tutorials".
Max image size is 2Mb. Most pics on my computer are bigger than that so I have to open in MS Office Picture Manager and then use Edit to compress and save as before I can upload them.
Kevin
Re: Nascar truck engine for street strip A body?? [Re: Scoober] #2268685
03/13/17 04:13 PM
03/13/17 04:13 PM
Sarasota, Fl
Scoober Offline OP
Scoober  Offline OP
Sarasota, Fl
THANKS GUYS!!!
I will check it out tonight at home. Does each pic, or group of pics have to be in a separate "file"?
With Ebay or Craigslist, I can just grab each pic and attach it. What TRENDZ is saying sounds like the Ebay/Craigs set-up??
Thanks again everyone!! I will get it one way or another...
Re: Nascar truck engine for street strip A body?? [Re: Scoober] #2268689
03/13/17 04:18 PM
03/13/17 04:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
THANKS GUYS!!!
You can add a few pics together(base on size)
you do it like Trendz said but just click the
add button.. then click done
wave
Re: Nascar truck engine for street strip A body?? [Re: Scoober] #2268696
03/13/17 04:32 PM
03/13/17 04:32 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
If Tom could turn that File Manager hyperlink into a big ADD PICS button, I think most guys could figure out the rest.
Kevin
Re: Nascar truck engine for street strip A body?? [Re: Scoober] #2269773
03/15/17 01:48 AM
03/15/17 01:48 AM
Sarasota, Fl
Scoober Offline OP
Scoober  Offline OP
Sarasota, Fl
OK Guys,
I hope the pics are here!!! I thought I would see them before submitting?? Well here goes...
DSCN4750 (800x600) (640x480).jpgDSCN4756 (800x600) (640x480) (640x480).jpgDSCN4758 (800x600) (640x480).jpg
Re: Nascar truck engine for street strip A body?? [Re: Scoober] #2269889
03/15/17 11:39 AM
03/15/17 11:39 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
My guess is that its R-3 9 inch deck block with W-8 heads.
I also probably has the 2.25 inch SBF main bearings. Good chance the rods are 1.88 but definitely smaller than stock. Probably has some really good rods in it.
If you car has a stock steering box the dry sump will probably have to go.
Good chance you will want to change the cam also.
You will have to have the headers made or at least modify production headers.
Good chance it has a Chevy rear flange on the crank. That will be a big issue with an automatic, not so much with a manual.
If it was mine I would sure give it a try.
Good luck and keep us posted.
Bill
Re: Nascar truck engine for street strip A body?? [Re: 340Cuda] #2269931
03/15/17 12:45 PM
03/15/17 12:45 PM
oregon
greendart408 Offline
oregon
That is an exact twin to my motor when I got it. Be interesting to see the number stamped into it, I'm betting its close to mine.
Agree with the above,
Ford main
9" deck
6" rod
1.88 to 2.0 rod journal
Chev rear crank flange
That's just my guess, could be anything.....
Full of good stuff if you are willing to put effort into making it work and fit your application, make headers, I converted the rear flange to mopar specs besides the bolt pattern on mine, just all takes thought and work, etc,etc
Re: Nascar truck engine for street strip A body?? [Re: greendart408] #2270164
03/15/17 08:25 PM
03/15/17 08:25 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
If you've got room for the dry sump system, it's not going to be an issue. Going to a traditional wet sump system will require a complete tear down and drilling the block and main cap. Otherwise a new oil pan and single stage external pump will be much easier.
It will have a lot of good parts in it, from memory those engines were 9:1, the camshaft isn't too crazy, but featured a bit of duration @0.050" (typically around 270-280 @0.050" on a 108 lobe centre). Chances are it will have Jesel dogbone or tie bar lifters. If you're running an auto trans, it will want a decent converter (5K plus i'd imagine)
Best of luck with it
Alan Jones
Re: Nascar truck engine for street strip A body?? [Re: Scoober] #2270351
03/16/17 01:20 AM
03/16/17 01:20 AM
Sarasota, Fl
Scoober Offline OP
Scoober  Offline OP
Sarasota, Fl
Thank you guys for all the info....I think it would be a kick ass set up. But I will continue to research it to make sure I can do it right..
Re: Nascar truck engine for street strip A body?? [Re: Scoober] #2270460
03/16/17 11:35 AM
03/16/17 11:35 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
will be an interesting build to see how it goes to grocery getter mode smile I too have pretty much the same bullet sitting on an engine stand.
