Re: Carter BBD model number (2300 on my 68 D100)
[Re: a12rag]
#2268623
03/13/17 02:38 PM
03/13/17 02:38 PM
RapidRobert
Agreed, it is a 70's piece. the metal part number tag is missing. there MAY be that number in addition stamped on the base but you woulda found it if so. Have your parts man check thekits available for the spread of years in that time frame for BBD's & make your best choice & likely you will be fine. the needle and seat is mainly what you need & correct gaskets & I like to measure all dimentions before/as I tear it down so I can duplicate them if there is a discrepency cuz dimentions dont change just from a carb needing rebuilding. if it is a phenolic float I would replace it also (sold seperately). EDIT #1 compare the old parts to the new parts before tossing anything.
[Re: wally426ci]
#2268625
03/13/17 02:47 PM
03/13/17 02:47 PM
Posts: 20,171 Park Forest, IL
slantzilla
Park Forest, IL
Make sure the throttle shaft bushings are not worn out in the base plate. BBD's are notorious for that and it will drive you crazy trying to tune it. It will run fine until you come to a stop, then it will die, start right back up and run fine until you stop again.
[Re: wally426ci]
#2268661
03/13/17 03:31 PM
03/13/17 03:31 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
If it helps at all that's a Carter BBD 1.1/4 carb. I suspect a '71 model, probably from a car. I "think" they went to the Holley 2245 series for small blocks in 1972. Memories are getting a bit fuzzy...
Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: wally426ci]
#2268672
03/13/17 03:45 PM
03/13/17 03:45 PM
Posts: 2,554 Maryland
wally426ci
Maryland
Thanks everyone!! I found the proper kit through the Carb Doctor & I suspect your ID is accurate: http://carbkitsource.com/kits/ck0071.htmlKit CK71 - Covers model: 4723 4724 4819 4820 4957 4958 6149 6150 6151 6152 6316 6317 6343 6344 6367 6368 6409 6409 6493 6493 6540 8004
[Re: 3hundred]
#2270039
03/15/17 04:02 PM
03/15/17 04:02 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Robert Thats about right. Its definetly a BBD 1-1/4 and since it has an external bowl vent that uses a hose on it that went either to the charcoal canister or the valve cover breather it should be from about a 71 to a mid 70 vehicle. I also remember the 318's going to the Holley 2 venturi carb that sorta looked like the BBD. My 83 Rancharger with the 318 had the Holley carb. One thing I hated was even when I had the carb number and the parts stores would say they cant find the number. That happened more then once over the years. Good luck as I would think any kit for a 71 or 72 BBD 1-1/4 should work. Ron
[Re: Paul_Fancsali]
#2270175
03/15/17 08:41 PM
03/15/17 08:41 PM
383man
Balt. Md
Be careful there are Rochester built Carter style carbs for 318s out there only for one year or so I think it was 1972. They don't share much of anything I happen to have a couple carbs that would fit that truck remans sell them just to get rid of them They actually used Rochester 2GC 2 venturi carbs on some 318's sometime around 1972 like you said. But these were actually the Rochester 2GC carb and not a Rochester built Carter. I saw a few working in the dealer and it surprised me as I had to look it up in the service manual because at first I thought someone swapped it on. I had heard that Carter ran short on there carb demands that year so they used the Rochester 2GC on some 318's. In the later years of the late 70's or 80's when Carter was going under Mopar also used the Rochester Quadrajets on 360 engines that were using the Thermoquad. Ron
[Re: 383man]
#2270303
03/16/17 12:06 AM
03/16/17 12:06 AM
RapidRobert
sometimes the cluster gaskets dont fit exactly right (kits are mass produced) & can use a slight bit of trimming (check your old ones) so that they lay under there flat/not pressing on any of the brass tubes/no holes/passages partly obstructed. EDIT I put some light oil on the carb bowl mounting bolts especially if they might be removed in the future for jet/rod changes
