Re: Neutral safety switch - 69 Dart
[Re: dd340]
#2268033
03/12/17 03:01 PM
03/12/17 03:01 PM
Posts: 15,366 Omaha Ne
TJP
Omaha Ne
I'm thinking they shipped the wrong harness or made them wrong ?? pic's would help the relay is supposed to be on the LF fender panel between the battery and shock tower. Can you compare to the old harness ?? The old harness looks exactly the same as the new one except that the brown wire for the relay is way to short. They said they have sold them for years that way with no complaints. I don't see much option other than to splice in a longer brown wire to make it work. I would send them a pic of the two harnesses and the engine compartment / relay location. and see what their response is. It's wouldn't be the first time I've heard the They said they have sold them for years that way with no complaints BS line. You might also try the Question and answer forum for additional confirmation
[Re: dd340]
#2268756
03/13/17 06:17 PM
03/13/17 06:17 PM
Posts: 957 Chicago
PurpleBeeper
Chicago
I didn't realize that Darts had the starter relay on the inner fender near the shock tower. My b-bodies have all had the starter relay near the bulkhead disconnect/master cylinder on the firewall. Sounds like you got one for a b-body (or maybe E-body)
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: PurpleBeeper]
#2268798
03/13/17 07:22 PM
03/13/17 07:22 PM
Posts: 727 Ottawa, ontario
dd340
Ottawa, ontario
I didn't realize that Darts had the starter relay on the inner fender near the shock tower. My b-bodies have all had the starter relay near the bulkhead disconnect/master cylinder on the firewall. Sounds like you got one for a b-body (or maybe E-body) Thanks for that information, the guy at M and H told me that they use the same harness with the b body. I guess that's why the wire is so short if the b body relay is near the bulkhead connector.
[Re: dd340]
#2269516
03/14/17 07:01 PM
03/14/17 07:01 PM
Posts: 45 Georgia
1969383S
Georgia
The L38569 is for 69 A-bodies A/T up to around Nov 15 68. I had to modify it slightly, no splicing!
Un wrap the harness tape back to the point the brown will now reach separately up to the starter relay. Re-wrap the Violet and black w/trace back up to the connectors and plug into the bulkhead. The brown was not supposed to be wrapped all the way!
Gerald
[Re: dd340]
#2269669
03/14/17 11:28 PM
03/14/17 11:28 PM
Posts: 45 Georgia
1969383S
Georgia
M&H built several harness assemblies for me that were not offered through the retail chain. Ma Mopar did not give them every last template, this harness was changed mid year and do not think they got the updated template.
If you have one not offered just arrange to send them the old one and they will make it and send back both! Their work is great IMO!
Gerald
[Re: 1969383S]
#2274485
03/22/17 10:00 PM
03/22/17 10:00 PM
dd340
Ottawa, ontario
Un wrap the harness tape back to the point the brown will now reach separately up to the starter relay. Re-wrap the Violet and black w/trace back up to the connectors and plug into the bulkhead. The brown was not supposed to be wrapped all the way! Thank you for that, sounds like it should work.
