need 22 inch radiator #2267141
03/11/17 12:47 AM
03/11/17 12:47 AM
napa ca
P
procharged 484 Offline OP
P
napa ca
The car is a 1970 challenger 484 hemi f2 procharger 95 % street only want to do this once . What do you recommend ?
Re: need 22 inch radiator [Re: procharged 484] #2267417
03/11/17 02:33 PM
03/11/17 02:33 PM
central il.
second 70 Offline
second 70  Offline
central il.
I replaced my factory radiator that couldn't keep my hemi cool with a champion 3 row in my 70 cuda and it works well, but I'm not procharged. Fit was good and only had to drill one lower hole.
Re: need 22 inch radiator [Re: procharged 484] #2267454
03/11/17 03:34 PM
03/11/17 03:34 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
prcracing.com is where I got my latest one. made to the measurements I provided, angle of hose connectors, built in trans cooler.
Re: need 22 inch radiator [Re: procharged 484] #2267592
03/11/17 07:28 PM
03/11/17 07:28 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Is that the maximum window width of the bulkhead, or just of the existing radiator?
More width is the most efficient way to get more cooling (better than thickness).
Boffin Emeritus
Re: need 22 inch radiator [Re: procharged 484] #2267640
03/11/17 09:00 PM
03/11/17 09:00 PM
napa ca
P
P
napa ca
That is the rad support . I would go thicker, got 2 1/2 inches more till I'm at the blower pulley as for width from factory holes I would assume I can go wider to the pass side only
Re: need 22 inch radiator [Re: procharged 484] #2267704
03/11/17 10:46 PM
03/11/17 10:46 PM
IN
ahy Offline
ahy  Offline
IN
I run a Mancini Muscle Car Radiator. It is a top tank style high performance AL radiator. It works quite well with a warm 496 and AC... including desert runs. Uses factory re-pop hoses as well.
These are available in both 22" and 26". Mine is a 26". An effective cooler.
I agree also that opening the core support to 26" would help though you may get it done with a 22".
Details seem to matter a lot on cooling systems. A high volume water pump slightly overdriven (~7%), thermal clutch fan and good shroud works well for me.
Re: need 22 inch radiator [Re: procharged 484] #2268023
03/12/17 02:43 PM
03/12/17 02:43 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I've had 2 brass radiators built by US Radiator. They look stock, and both use shrouds and factory thermal fans. I did use Spal's twin fan set-up with shroud and Controller on the 26" radiator successfully for 6+years, but swapped it back to the factory style thermal fan set-up. It wasn't cheap, but you better have a good electrical system & feed to supply it with over 40 amps on start up.
The quality and cooling performance is top notch. One car uses the 22" opening and cools 510 hp and an auto trans. The other cools a 700+hp motor with a 26" opening and a 5 speed. Both have A/C condensers in front of them.
Give them a call, and explain what you have. They will tell you if they are able to build a radiator for you that works in a 22" opening. I'm sure a lot depends on the fan system you will be able to use.
Are you going to be able to run a shroud and factory clutch fan? If not, you will have to use very high quality electric fan/fans with an upgraded electrical feed to them. The factory style clutch/thermal fans with a shroud move a lot of air reliably.
