77 D100 factory front sway bar? #2265934
03/09/17 12:33 AM
03/09/17 12:33 AM
Indiana
68_661charger Offline OP
Indiana
Were front sway bars available on 77 era Dodge 2 wheel drive trucks? If so where does it mount and would I need different lower control arms if my truck never had the bar? Any pics of one? Thanks in advance.
Re: 77 D100 factory front sway bar? [Re: 68_661charger] #2266237
03/09/17 03:47 PM
03/09/17 03:47 PM
dogdays Offline
dogdays  Offline
Well, I know it's a different frame, but my donor '71 D100 had a front bar. So I'd be willing to bet that there was one on the next generation trucks.
The Rockauto Reference Library shows front stabilizer bar bushings for bar to frame and also for links.
R.
Re: 77 D100 factory front sway bar? [Re: 68_661charger] #2266333
03/09/17 06:27 PM
03/09/17 06:27 PM
Orange Park FL.
LilRed7879 Offline
LilRed7879  Offline
Orange Park FL.
They were available but I cannot recall the mounting details enough from memory to answer your other questions. I do know if you had to a junk yard the end links are the most critical part to grab as there are none available aftermarket. Basically grab the bar and end links you can get bushings from most supply houses.
David S.
Part Time Owner
Dodge Connection
www.dodgeconnection.com
904-209-9388
Re: 77 D100 factory front sway bar? [Re: 68_661charger] #2266395
03/09/17 08:48 PM
03/09/17 08:48 PM
Amarillo, Tx
old_goat Offline
Six Abuser
old_goat  Offline
Six Abuser
Amarillo, Tx
I have a truck that had one on it, a 74 I can get pics, but will be about a week or better before I can get out there. (I'm parting it out for a project) One of the end links on mine was broken.
O.G.
84 D150 440/727
79 /6 swb D150
1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
Re: 77 D100 factory front sway bar? [Re: 68_661charger] #2266500
03/09/17 11:44 PM
03/09/17 11:44 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Here's a pic I got off ebay.
I'm not sure about aftermarket kits, but, OEM the key part to find is the piece for the front mount ( #4 in this example).
I would think you could look under an early '90's Cummins truck to get the basic idea of how it all mounts.
John
Re: 77 D100 factory front sway bar? [Re: 68_661charger] #2266516
03/10/17 12:17 AM
03/10/17 12:17 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Sway bars on Dodge trucks between 72 and about 85 were pretty hit or miss. I think it depended on if the sway bar box was checked on the option sheet when the truck was ordered. It was probably part of any handling or towing option and probably part of most of the heavy duty packages.
The sway bar on my 73 D300 was massive, probably well over 1" in diameter. I also believe the control arm end was square cut and was clamped in a rubber bushing to the forward strut bar about an inch in front of the control arm, but that was a long time ago, it may have attached to the lower control arm.... Gene
Re: 77 D100 factory front sway bar? [Re: 68_661charger] #2266535
03/10/17 12:56 AM
03/10/17 12:56 AM
Indiana
Indiana
Thanks for all the help. Ill keep my eyes open at the yards.
