How do I know if it's 3 spd or 2 spd wiper motor and switch? #2263058
03/04/17 01:46 AM
03/04/17 01:46 AM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I think I have a two speed wiper motor ('71 SSP) but how do I tell? Trying to bench test it but I don't know which one I have.
Re: How do I know if I have a 3 spd or 2 spd wiper motor? [Re: VITC_GTX] #2263086
03/04/17 03:18 AM
03/04/17 03:18 AM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
3 speed lays flat against firewall. 2 speed points toward the front
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: How do I know if I have a 3 spd or 2 spd wiper motor? [Re: VITC_GTX] #2263093
03/04/17 03:38 AM
03/04/17 03:38 AM
Canada
ACR2000 Offline
ACR2000  Offline
Canada
3 Speeds vs 2 ( all black )
Re: How do I know if I have a 3 spd or 2 spd wiper motor? [Re: VITC_GTX] #2263101
03/04/17 04:07 AM
03/04/17 04:07 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Oh, OK, thanks guys.
I have the one on the bottom (3 speed) but the switch only has three positions. Far left is low, middle was stop and far right was high. I wonder if the switch was changed or ???
Re: How do I know if I have a 3 spd or 2 spd wiper motor? [Re: VITC_GTX] #2263102
03/04/17 04:22 AM
03/04/17 04:22 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
To clarify the wipers don't work well at all. Far left won't run the wipers unless you go to far right first to get them going, once they're going you can quickly change it to far left and they will work very slowly. Middle position stops everything but they will not park.
I'm guessing I must have a two speed switch? What are the positions on the three way switch? Far left off, one position right slow, next medium, far right fast?
Re: How do I know if I have a 3 spd or 2 spd wiper motor? [Re: VITC_GTX] #2263916
03/05/17 08:28 PM
03/05/17 08:28 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Turns out I have a 3 speed wiper motor with a 2 speed switch. The car came with 3 speed wipers.
The only three speeds switches I can find are $290+. I may see if I can switch the car over to a 2 speed setup as I have extra wiper motors but I believe you need different linkage to do that. Still may be cheaper than buying a switch.
Re: How do I know if I have a 3 spd or 2 spd wiper motor? [Re: VITC_GTX] #2264220
03/06/17 11:49 AM
03/06/17 11:49 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
2 speeds switches are 2 clicks so 3 positions ... off, low, high
3 speeds switches are 3 clicks so 4 positions... off, low, mid, high
B body 71 switches are one year production, hence harder to find and expensive. Even more if Rallye cluster
72/74 are maybe easier and cheaper. Wiring is the same BUT NOT THE PLUG OR PRONGS DISPOSITION. You can try to get a 72/74 and try to find the plugs what shouldn't be hard to find at any JY. Rallye and Standard cluster, 2 or 3 speeds, all plugs are the same.
The diff between Rallye and Standard cluster is just the shaft lenght
71s got tipically variable speeds switches. No click on it aside the on/off one, but then a continuous sweep from low to high
Re: How do I know if I have a 3 spd or 2 spd wiper motor? [Re: VITC_GTX] #2264223
03/06/17 11:58 AM
03/06/17 11:58 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Here you have!
This will work to you
https://www.ebay.com/itm/122374696104
It is as far I can tell really a variable speed switch. Will match your wiper motor since is the actual assembly on my 74.
I installed a 71 variable switch on my 74 which originally was 2 speds. Changed all the linkage, motor and switch. Got as a PRESENT a 71 variable switch on the Rallye cluster I bought ( also changed from standard to Rallye cluster ) and decided to use the 71 variable switch instead the 72/74 3 speeds I also got. Found the plastic plugs from a 71 Coronet donor and VOILA!
Re: How do I know if I have a 3 spd or 2 spd wiper motor? [Re: VITC_GTX] #2264225
03/06/17 12:10 PM
03/06/17 12:10 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Re: How do I know if I have a 3 spd or 2 spd wiper motor? [Re: VITC_GTX] #2264227
03/06/17 12:16 PM
03/06/17 12:16 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
72/74 3 speeds... not variable speed available for these years
https://www.ebay.com/itm/112227136414
https://www.ebay.com/itm/122379770667
But will need to get the plug OR conect terminals individually on each prong
Re: How do I know if I have a 3 spd or 2 spd wiper motor? [Re: VITC_GTX] #2264231
03/06/17 12:24 PM
03/06/17 12:24 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
You can also get a standard cluster one and get the shaft and housing shortened. I did it once with a 72/74 2 speeds one with the one I had on my standard cluster before get completed all the parts to the wiper motor conversion
Need to be dissasembled and shortened at the inside end, not at the knob end.
Can't tell for sure how tricky is on a 71, but on 72/74s is fairly easy.
Re: How do I know if I have a 3 spd or 2 spd wiper motor? [Re: VITC_GTX] #2264579
03/06/17 10:39 PM
03/06/17 10:39 PM
CT - just outside Hartford
Crazy73 Offline
Crazy73  Offline
Can I use a variable wiper switch with a 2-speed motor? I have both a 2-speed switch and a variable switch (and also a 3-speed switch) for my '68 Barracuda which has a 2-speed motor. I can't run a 3-speed because of the 6-pack air cleaner, and I'm wondering what my switch options are.
Pete
-1968 Barracuda 4spd 383-6pk
Re: How do I know if I have a 3 spd or 2 spd wiper motor? [Re: VITC_GTX] #2264638
03/07/17 12:18 AM
03/07/17 12:18 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Shouldn't work
Re: How do I know if I have a 3 spd or 2 spd wiper motor? [Re: VITC_GTX] #2264643
03/07/17 12:20 AM
03/07/17 12:20 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Isn't the 2 speed a bigger disturb for a 6 pack air cleaner than a 3 speeds ?
Re: How do I know if I have a 3 spd or 2 spd wiper motor? [Re: Crazy73] #2264662
03/07/17 12:46 AM
03/07/17 12:46 AM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
Have you tried a prestolite 3 sp they are smaller than the 68 a-body 2 sp
NS1AAR
Re: How do I know if I have a 3 spd or 2 spd wiper motor? [Re: NachoRT74] #2264668
03/07/17 01:00 AM
03/07/17 01:00 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Nacho, thanks for the education!!
I didn't know about the difference between the 3 speed switch and the variable switch. Like you mentioned mine must need the variable switch. I'll have to pickup a used switch and hope that it works because I can't see spending $300 for a NOS one!
I really appreciate you spending the time to help me with this!!
Re: How do I know if I have a 3 spd or 2 spd wiper motor? [Re: VITC_GTX] #2264679
03/07/17 01:23 AM
03/07/17 01:23 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Variable speed switch works with "3 speeds motors", not 2 speeds motors. 2 speeds motors only works with 2 speeds switch.
I actually can't recall if 71s got 3 switches options ( 2, 3 and var speeds ) or 2 ( 2 and var speeds ). Is a fact since 72 just 2 and 3 speeds were optioned, not anymore variable.
Have to search on the 71 parts catalog.
Sometimes the 3 and var speeds are mixed up since both work with the 3 speeds motor.
My 74 parts catalog labels the 3 speeds switch like 3/var, but is not var, just 3 speeds. Dunno on 71. Will find out tomorrow.
Re: How do I know if I have a 3 spd or 2 spd wiper motor? [Re: NachoRT74] #2264754
03/07/17 10:32 AM
03/07/17 10:32 AM
Crazy73 Offline
Crazy73  Offline
Thank you, I guess I'll have some switches for sale! wrench
Pete
Re: How do I know if I have a 3 spd or 2 spd wiper motor? [Re: ns1aar] #2264755
03/07/17 10:37 AM
03/07/17 10:37 AM
Crazy73 Offline
Crazy73  Offline
From what I remember (which goes back 13 years ago when I ordered everything for this project) the 3-speed motor winds up interfering with the air cleaner base unless you notch it. Right now I have around 3/4" clearance from the rear edge of air cleaner base to the front edge of the 2 speed wiper motor. Plenty of room for it to fit!
No, I already have a new 2 speed mounted to the firewall. I'd rather not drive this thing in the rain anyways drumhit
Pete
Re: How do I know if I have a 3 spd or 2 spd wiper motor? [Re: VITC_GTX] #2264875
03/07/17 02:08 PM
03/07/17 02:08 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
well I remembered all 6 packs cars got 3 speeds just right for the clearence reason, same as No AC... will search further on that
