How do I know if it's 3 spd or 2 spd wiper motor and switch?
#2263058
03/04/17 01:46 AM
03/04/17 01:46 AM
Posts: 4,930 Tri-Cities, Washington
VITC_GTX
I think I have a two speed wiper motor ('71 SSP) but how do I tell? Trying to bench test it but I don't know which one I have.
Re: How do I know if I have a 3 spd or 2 spd wiper motor?
[Re: VITC_GTX]
#2263086
03/04/17 03:18 AM
03/04/17 03:18 AM
Posts: 8,849 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
3 speed lays flat against firewall. 2 speed points toward the front
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: VITC_GTX]
#2263093
03/04/17 03:38 AM
03/04/17 03:38 AM
Posts: 317 Canada
ACR2000
Canada
I think I have a two speed wiper motor ('71 SSP) but how do I tell? Trying to bench test it but I don't know which one I have. 3 Speeds vs 2 ( all black )
[Re: VITC_GTX]
#2263102
03/04/17 04:22 AM
03/04/17 04:22 AM
VITC_GTX
To clarify the wipers don't work well at all. Far left won't run the wipers unless you go to far right first to get them going, once they're going you can quickly change it to far left and they will work very slowly. Middle position stops everything but they will not park.
I'm guessing I must have a two speed switch? What are the positions on the three way switch? Far left off, one position right slow, next medium, far right fast?
[Re: VITC_GTX]
#2264220
03/06/17 11:49 AM
03/06/17 11:49 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
2 speeds switches are 2 clicks so 3 positions ... off, low, high
3 speeds switches are 3 clicks so 4 positions... off, low, mid, high
B body 71 switches are one year production, hence harder to find and expensive. Even more if Rallye cluster
72/74 are maybe easier and cheaper. Wiring is the same BUT NOT THE PLUG OR PRONGS DISPOSITION. You can try to get a 72/74 and try to find the plugs what shouldn't be hard to find at any JY. Rallye and Standard cluster, 2 or 3 speeds, all plugs are the same.
The diff between Rallye and Standard cluster is just the shaft lenght
71s got tipically variable speeds switches. No click on it aside the on/off one, but then a continuous sweep from low to high
[Re: VITC_GTX]
#2264223
03/06/17 11:58 AM
03/06/17 11:58 AM
NachoRT74
Valencia, España
Here you have! This will work to you https://www.ebay.com/itm/122374696104 It is as far I can tell really a variable speed switch. Will match your wiper motor since is the actual assembly on my 74. I installed a 71 variable switch on my 74 which originally was 2 speds. Changed all the linkage, motor and switch. Got as a PRESENT a 71 variable switch on the Rallye cluster I bought ( also changed from standard to Rallye cluster ) and decided to use the 71 variable switch instead the 72/74 3 speeds I also got. Found the plastic plugs from a 71 Coronet donor and VOILA!
[Re: VITC_GTX]
#2264231
03/06/17 12:24 PM
03/06/17 12:24 PM
NachoRT74
Valencia, España
You can also get a standard cluster one and get the shaft and housing shortened. I did it once with a 72/74 2 speeds one with the one I had on my standard cluster before get completed all the parts to the wiper motor conversion https://www.ebay.com/itm/122379770667 Need to be dissasembled and shortened at the inside end, not at the knob end. Can't tell for sure how tricky is on a 71, but on 72/74s is fairly easy.
[Re: VITC_GTX]
#2264579
03/06/17 10:39 PM
03/06/17 10:39 PM
Posts: 2,580 CT - just outside Hartford
Crazy73
Can I use a variable wiper switch with a 2-speed motor? I have both a 2-speed switch and a variable switch (and also a 3-speed switch) for my '68 Barracuda which has a 2-speed motor. I can't run a 3-speed because of the 6-pack air cleaner, and I'm wondering what my switch options are.
Pete -1968 Barracuda 4spd 383-6pk
[Re: VITC_GTX]
#2264643
03/07/17 12:20 AM
03/07/17 12:20 AM
NachoRT74
Valencia, España
Isn't the 2 speed a bigger disturb for a 6 pack air cleaner than a 3 speeds ?
[Re: Crazy73]
#2264662
03/07/17 12:46 AM
03/07/17 12:46 AM
Posts: 1,145 ontario calif
ns1aar
ontario calif
Can I use a variable wiper switch with a 2-speed motor? I have both a 2-speed switch and a variable switch (and also a 3-speed switch) for my '68 Barracuda which has a 2-speed motor. I can't run a 3-speed because of the 6-pack air cleaner, and I'm wondering what my switch options are. Have you tried a prestolite 3 sp they are smaller than the 68 a-body 2 sp
NS1AAR
[Re: NachoRT74]
#2264668
03/07/17 01:00 AM
03/07/17 01:00 AM
VITC_GTX
71s got tipically variable speeds switches. No click on it aside the on/off one, but then a continuous sweep from low to high Nacho, thanks for the education!! I didn't know about the difference between the 3 speed switch and the variable switch. Like you mentioned mine must need the variable switch. I'll have to pickup a used switch and hope that it works because I can't see spending $300 for a NOS one! I really appreciate you spending the time to help me with this!!
[Re: VITC_GTX]
#2264679
03/07/17 01:23 AM
03/07/17 01:23 AM
NachoRT74
Valencia, España
Variable speed switch works with "3 speeds motors", not 2 speeds motors. 2 speeds motors only works with 2 speeds switch.
I actually can't recall if 71s got 3 switches options ( 2, 3 and var speeds ) or 2 ( 2 and var speeds ). Is a fact since 72 just 2 and 3 speeds were optioned, not anymore variable.
Have to search on the 71 parts catalog.
Sometimes the 3 and var speeds are mixed up since both work with the 3 speeds motor.
My 74 parts catalog labels the 3 speeds switch like 3/var, but is not var, just 3 speeds. Dunno on 71. Will find out tomorrow.
[Re: NachoRT74]
#2264754
03/07/17 10:32 AM
03/07/17 10:32 AM
Crazy73
My 74 parts catalog labels the 3 speeds switch like 3/var, but is not var, just 3 speeds. Dunno on 71. Will find out tomorrow. Thank you, I guess I'll have some switches for sale!
[Re: ns1aar]
#2264755
03/07/17 10:37 AM
03/07/17 10:37 AM
Crazy73
Isn't the 2 speed a bigger disturb for a 6 pack air cleaner than a 3 speeds ? From what I remember (which goes back 13 years ago when I ordered everything for this project) the 3-speed motor winds up interfering with the air cleaner base unless you notch it. Right now I have around 3/4" clearance from the rear edge of air cleaner base to the front edge of the 2 speed wiper motor. Plenty of room for it to fit! Have you tried a prestolite 3 sp they are smaller than the 68 a-body 2 sp
No, I already have a new 2 speed mounted to the firewall. I'd rather not drive this thing in the rain anyways
[Re: VITC_GTX]
#2264875
03/07/17 02:08 PM
03/07/17 02:08 PM
NachoRT74
Valencia, España
well I remembered all 6 packs cars got 3 speeds just right for the clearence reason, same as No AC... will search further on that
