Correct intake for a 1969 340? #2262167
03/02/17 01:46 PM
03/02/17 01:46 PM
St.Louis, MO
694406 Offline OP
694406  Offline OP
St.Louis, MO
Is there a specific one (part #) more correct for a 1969 340? I have 2 intakes and one looks like a 1968 and the other a 1970.
Thanks!
www.Musclemagnet.com
1969 Cuda 383 Q5
1969 Cuda 340 4-spd Notch
1969 Cuda 383 4-spd Notch
1969 GTS Black on White 340 4-spd
1971 Cuda 383 V2, X9 Billboards, White Top!
Re: Correct intake for a 1969 340? [Re: 694406] #2262195
03/02/17 02:35 PM
03/02/17 02:35 PM
Ontario, Canada
GVH Offline
GVH  Offline
Ontario, Canada
68 & 69 show same casting # 2531915 70 is different casting # is3462848
depends how right you want to be
Re: Correct intake for a 1969 340? [Re: 694406] #2262238
03/02/17 04:55 PM
03/02/17 04:55 PM
St.Louis, MO
694406 Offline OP
694406  Offline OP
St.Louis, MO
I have a 2531915. the resource I saw referred to it as 1968 and a 2531914 for 1968-1970?
1969 Cuda 383 Q5
Re: Correct intake for a 1969 340? [Re: 694406] #2262280
03/02/17 06:44 PM
03/02/17 06:44 PM
The Mopar foundry, all of them, cast different parts with different casting numbers and casting dates for use through out the year scope
My point is that the lower casting number will be made before the higher casting number for the same motor in the same year, especially if they have a mid year update or design change work
Look at your fender tag for the schedule production date and use the intake with the proper casting number that has a casting date before the SPD twocents
Re: Correct intake for a 1969 340? [Re: 694406] #2262331
03/02/17 09:26 PM
03/02/17 09:26 PM
Ontario, Canada
GVH Offline
GVH  Offline
Ontario, Canada
[quote=694406]I have a 2531915. the resource I saw referred to it as 1968 and a 2531914 for 1968-1970?
one of my sources by l.shepard shows 2531914 as the service p/n and the casting # 2531915 68/69
Re: Correct intake for a 1969 340? [Re: GVH] #2262347
03/02/17 10:21 PM
03/02/17 10:21 PM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
There will be a date code on the intake too... scope
JB Rhinehart, Realist
A-Body's RULE!
Re: Correct intake for a 1969 340? [Re: 694406] #2262379
03/02/17 11:17 PM
03/02/17 11:17 PM
St.Louis, MO
694406 Offline OP
694406  Offline OP
St.Louis, MO
Thanks guys!
1969 Cuda 383 Q5
Re: Correct intake for a 1969 340? [Re: 694406] #2262417
03/03/17 12:40 AM
03/03/17 12:40 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I have a original 340 intake I took off my 340 dart in the early 70's. I'll go out and see what numbers are on it.
Re: Correct intake for a 1969 340? [Re: 694406] #2262429
03/03/17 12:58 AM
03/03/17 12:58 AM
rowin4 Offline
rowin4  Offline
Well the date code on mine 12 11 9 the casting number is 3462849 1
Re: Correct intake for a 1969 340? [Re: rowin4] #2262438
03/03/17 01:05 AM
03/03/17 01:05 AM
Rhinotruck
Rhinotruck
That would be a 1970 intake.
A-Body's RULE!
