Re: B engine to RB engine 71 B body..
[Re: EV2RUNNER]
#2262021
03/02/17 02:42 AM
03/02/17 02:42 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
Exhaust manifold/header will be going up and outward. You got space there ?
1963 Plymouth Max Wedge 1971 Barracuda
[Re: EV2RUNNER]
#2262036
03/02/17 03:04 AM
03/02/17 03:04 AM
RapidRobert
the heads set 3/4" higher up at a 45 angle so anything bolted to the front of the heads (alt/power st) may need different brackets & of course the ex headers/manifolds will be raised that amt. Same mtr mts
[Re: EV2RUNNER]
#2262057
03/02/17 04:21 AM
03/02/17 04:21 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
Motor mounts are the same. Could use the 383 torque converter too. What is the 440 out of? If a C-body then you will need to change the oil pan. Unless you have 383/400 only headers then the exhaust is fine. Not much else to change.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: EV2RUNNER]
#2262672
03/03/17 02:52 PM
03/03/17 02:52 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
Almost everything will swap over ... does the car have A/C or an air grabber hood , there are 440 or 383 specific parts associated with them ? The only thing bolted to the head without A/C is the long bolt thru the alternator and the bracket that is on the 383 has 2 holes , one for a 383 and the other 4 a 440. The power steering attaches to the water pump only so that is not an issue. If the 440 is from a C body the pan will fit in the 71 K with no issues, but it won't have an internal baffle like the Stock 402 pan on your 383. If it's from a B body it will have a 402 pan if stock.
Engine mounts are the same.
If you have Air grabber the air cleaner base is different.
