B engine to RB engine 71 B body.. #2262020
03/02/17 02:35 AM
03/02/17 02:35 AM
St.Clairsville Ohio
EV2RUNNER Offline OP
St.Clairsville Ohio
Hey guys I've decided to pull the original 383 out of my 71 Roadrunner and place it on a stand for safe keeping. I want to replace it with a 68 440. I plan to change out the torque converter regardless.. What else am I looking at changing to make the swap? Forgive me its been a few years and I forget half of what I knew about these cars. Thanks!
Re: B engine to RB engine 71 B body.. [Re: EV2RUNNER] #2262021
03/02/17 02:42 AM
03/02/17 02:42 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Exhaust manifold/header will be going up and outward. You got space there ?
1963 Plymouth Max Wedge
1971 Barracuda
Re: B engine to RB engine 71 B body.. [Re: EV2RUNNER] #2262024
03/02/17 02:47 AM
03/02/17 02:47 AM
St.Clairsville Ohio
St.Clairsville Ohio
Yes I should be good there. Thanks!
Re: B engine to RB engine 71 B body.. [Re: EV2RUNNER] #2262028
03/02/17 02:49 AM
03/02/17 02:49 AM
St.Clairsville Ohio
St.Clairsville Ohio
Are the motor mounts different between B/RB ? I can't remeber for the life of me..
Re: B engine to RB engine 71 B body.. [Re: EV2RUNNER] #2262029
03/02/17 02:52 AM
03/02/17 02:52 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
I think so
1971 Barracuda
Re: B engine to RB engine 71 B body.. [Re: EV2RUNNER] #2262036
03/02/17 03:04 AM
03/02/17 03:04 AM
the heads set 3/4" higher up at a 45 angle so anything bolted to the front of the heads (alt/power st) may need different brackets & of course the ex headers/manifolds will be raised that amt. Same mtr mts
Re: B engine to RB engine 71 B body.. [Re: EV2RUNNER] #2262049
03/02/17 03:51 AM
03/02/17 03:51 AM
St.Clairsville Ohio
St.Clairsville Ohio
Cool thanks very much Rapid Robert. I have all the Bracketry still on the 440 so I should be good to go.
Re: B engine to RB engine 71 B body.. [Re: EV2RUNNER] #2262057
03/02/17 04:21 AM
03/02/17 04:21 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Motor mounts are the same. Could use the 383 torque converter too.
What is the 440 out of? If a C-body then you will need to change the oil pan. Unless you have 383/400 only headers then the exhaust is fine. Not much else to change.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: B engine to RB engine 71 B body.. [Re: EV2RUNNER] #2262672
03/03/17 02:52 PM
03/03/17 02:52 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Almost everything will swap over ... does the car have A/C or an air grabber hood , there are 440 or 383 specific parts associated with them ? The only thing bolted to the head without A/C is the long bolt thru the alternator and the bracket that is on the 383 has 2 holes , one for a 383 and the other 4 a 440. The power steering attaches to the water pump only so that is not an issue. If the 440 is from a C body the pan will fit in the 71 K with no issues, but it won't have an internal baffle like the Stock 402 pan on your 383. If it's from a B body it will have a 402 pan if stock.
Engine mounts are the same.
If you have Air grabber the air cleaner base is different.
Re: B engine to RB engine 71 B body.. [Re: EV2RUNNER] #2262752
03/03/17 05:33 PM
03/03/17 05:33 PM
moparmarks Offline
moparmarks  Offline
"If the 440 is from a C body the pan will fit in the 71 K with no issues."
Will fit but will probably rub against the center link.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
