Re: OK.... Back from vacation..... 11.50@ Norwalk... Rules help
[Re: SportF]
#2260733
02/27/17 10:37 PM
02/27/17 10:37 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
When I first started racing I never could understand the courtesy staging deal Do your burnout,get set,then you have to wait for the other guy to get his poop in a group I run an alternator and a good cooling system so I can wait an hour for the other guy to think about what he's going to do to beat me. When I was asked by the starter to back out of the beams and wait for the other guy I quit turning both bulbs on I don't understand what takes so long for some guys to stage maybe someone can enlighten me Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2260768
02/27/17 11:13 PM
02/27/17 11:13 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
It is not for people to take their time to stage. It is because some people rush up there and and put both lights on to rush the other guy. I think it is good to have courtesy staging. If you can wait a hour as you say for the other guy why are you trying to rush somebody to stage up.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: fourgearsavoy]
#2261488
03/01/17 03:19 AM
03/01/17 03:19 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
When I first started racing I never could understand the courtesy staging deal Do your burnout,get set,then you have to wait for the other guy to get his poop in a group I run an alternator and a good cooling system so I can wait an hour for the other guy to think about what he's going to do to beat me. When I was asked by the starter to back out of the beams and wait for the other guy I quit turning both bulbs on I don't understand what takes so long for some guys to stage maybe someone can enlighten me Gus Well, I can tell you that if you were double bulbing guys, THAT is probably the reason you found yourself waiting. It only stands to reason that if you rush an opponent, he's likely gonna go out of his way to make you wait. I can only speak for myself, but I always assume that if someone lights both bulbs one after the other before the opponent pre-stages, they either don't understand what it is they're doing, or they do understand and are knowingly giving a middle finger to the guy in the other lane.
