Re: Chrysler disc brake conversion question
[Re: Skid_Demon]
#2259802
02/26/17 02:10 PM
02/26/17 02:10 PM
Posts: 16,146 Mesa, Arizona
dart4forte
Mesa, Arizona
Definitely change the master cylinder and add a proportioning block. Finlines sells what you'll need. You may want to talk with the folks from SSBC.
Abe Lincoln
[Re: Skid_Demon]
#2259814
02/26/17 02:32 PM
02/26/17 02:32 PM
RapidRobert
We use it as a weekend cruiser. I would just get some OE discs & I would for sure try it WO adding in a prop valve. it is some work to plumb it & it highly likely wont be needed. I added 76 (2.75") A body single piston discs to my 65 dart, a DD & kept the OE splitter with 10 rear drums & NO issues & stopped flawlessly. For your mild app just me I would not see a need to get crazy with it. get some Ceramic pads.
[Re: Skid_Demon]
#2259819
02/26/17 02:36 PM
02/26/17 02:36 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Been my observations that most aftermarket brake companies do a poor job of outfitting Mopars. Most of the kits are based on GM stuff that does not seem to work well in our applications. Not sure why, but it seems to be an inordinate amount of difficulties going that route.
When I converted my 64 300 to discs I used factory parts. A tape measure and time with a TRW chassis specifications books showed that the late B body (79 Cordoba was the donor for this brake swap) spindles were the proper height to work, and that the ball joint tapers for the Chrysler would fit the B body spindles. I had to use the B body's steering arm as the Chrysler's would not bolt to the B body spindle. This moved the outer tie rod point in enough that I had to shorten the Chrysler's tie rod ends some to make it fit.
I used a later 4 bolt master cylinder for disc brakes and the B body proportioning valve. I retained the original drum booster.
It worked great and cost me a total of $100, well technically less since that same donor provided a 360/auto to swap into my 72 Dart along with putting the power seats, locks, and windows into the Dart. I bought the Doba for $100 and sold the Dart's 225 (with installation included) for $250.
I would rather swap in a later factory setup if at all possible, though 65-72 C bodies are a PITA to find a factory setup as I understand it.
[Re: Skid_Demon]
#2259853
02/26/17 03:16 PM
02/26/17 03:16 PM
Posts: 2,918 Calgary, Alberta Canada
a12rag
There have been lots of threads on disc brake conversions . . . just have to do a search. . . . for my two cents worth : on my 1970 300Hurst, I used the spindles off a 74 up C body, along with the calipers, rotors. I did get a new master cylinder, but never put it on the car, used the dual reservoir drum unit - yes, it just means you have to make sure residual pressure valve is not in the front disc circuit, AND have to be vigilant on checking the fluid level for front discs. Car stopped great !!! . . . .
As for the F,M,J, body spindle debate . . . yup, I am going to open that up - as I have have used the spindles from those cars on other disc brake conversions (the Chrysler 5th ave. are still relatively out there). The bottom bolts on the spindle needed a washer to get the castle nut lined up and tight. You need the correct calipers - with bleeder located on top, and then I went with stainless steel braided brake hose (Dr. Diff sells). All the talk about the height being too tall, well, maybe if you are driving on roads where you have full wheel travel up & down . . . but for the 10k miles I have put on the one car, no issues at all. Alignment perfect and stops great - and this car is B body with manual brakes, no power.
I think one of the best sources is Cas - Dr. Diff. He can sell you a kit, or parts/pieces . . . . and is happy to give advise. . . .
Cheers
Mark
[Re: Skid_Demon]
#2259920
02/26/17 04:23 PM
02/26/17 04:23 PM
Andrewh
it is 73 c-body discs that are a direct swap in for your 66. I was unaware, and am not sure how a 74 and up would bolt in.
scaredbird may work, but will push your fronts outboard a bit. So be aware if you filled the wheel wells, it may push your tires out past them.
Didn't think ssbc were good on the street, and was unaware they even make a c-body conversion.
The drum power booster does not provide sufficent assist to fully lock up the brakes. They will stop the car and work fine, but you will be missing some panic stopping ability.
The later 73 booster will bolt up, but on a column shift car, and I think autopilot car, it causes some interference. mainly the column shift won't go into low.
I do not believe there is any easy way to adapt b-body spindles to a c-body. However, there was a person that adapted later van/truck spindles, at some point. he cross refrenced the rotors and found that some van's up till the 80's used the same rotor and managed to take the spindles off those and get them to bolt in. don't remember how much work, or how far off they were. but I would bet they are a lot easier to find than a 73 c body right now.
[Re: Skid_Demon]
#2260023
02/26/17 07:28 PM
02/26/17 07:28 PM
Andrewh
