RPM Airgap under stock 68 Charger hood #2258996
02/24/17 11:57 PM
02/24/17 11:57 PM
Toronto, Ont, Canada
boydsdodge Offline OP
Hi, just finished a 408 build for a friend.
He has a 1968 Charger, the 408 has an Edelbrock Airgap intake.
Any knowledge if it will fit with stock hood?
would like to use the Mopar unsilenced air cleaner.
If this is a no go, what about running a weiand stealth or LD340
The RPM range is Idle to 6000
Re: RPM Airgap under stock 68 Charger hood [Re: boydsdodge] #2259023
02/25/17 12:47 AM
02/25/17 12:47 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
A small block in a Charger....Not really a clearance problem unless you are running a Tunnel Ram. The RPM airgap clears on ALL A body cars too.
