Re: Power windows?
[Re: 80arrow]
#2257974
02/22/17 11:50 PM
02/22/17 11:50 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I'd love to have power windows in my '72 Duster, I kinda gave up on it last time I was trying to find a kit that actually works good.
Re: Power windows?
[Re: Moparguy383]
#2258171
02/23/17 01:00 PM
02/23/17 01:00 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I have not personally used them, but I have heard these kits work good. Ebay Link Would love to know some one with these
Brett Miller W9 cnc'd heads STR Chassis fabraction
Re: Power windows?
[Re: 80arrow]
#2258172
02/23/17 01:06 PM
02/23/17 01:06 PM
Guitar Jones
I bought a universal kit from a member here awhile back for my Scamp. It's a chassis car but still has all the factory glass and the window regulators still work. I haven't installed them yet but I plan too, maybe this summer.
Re: Power windows?
[Re: Monte_Smith]
#2258794
02/24/17 04:27 PM
02/24/17 04:27 PM
Guitar Jones
One more thing electrical to let you down at the most inopportune time on a race car True but, sitting in a closed car in a full monkey suit, on steaming black top in the middle of a sweltering July day in Central Florida is just brutal. It's the reason I opted to keep the door windows functional. That only gets me one window though unless I have a helper. Us low buck guys don't have the 27 crew members swarming around the car like you high rollers have.
Re: Power windows?
[Re: 80arrow]
#2258960
02/24/17 10:26 PM
02/24/17 10:26 PM
Posts: 8,879 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Item Description Do you feel so much boring of rolling down the windows for every time in order to get some fresh air? Gee, I wonder where they're made ?!?!?
Re: Power windows?
[Re: 80arrow]
#2260370
02/27/17 11:40 AM
02/27/17 11:40 AM
Posts: 1,260 New Mexico
Adobedude
New Mexico
I added one to my Dakota's passenger window, it's on a toggle switch on the dash... Track faces east and there is ALWAYS a breeze from the South, I love it, it can get hot here in Albuquerque, NM.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
Re: Power windows?
[Re: 80arrow]
#2260422
02/27/17 12:52 PM
02/27/17 12:52 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I look to the added comfort you can have if you go with them and a small fan blowing right at you. Even just the fan is a huge help, but the windows will drop the in car temp a large amount! Less stress on the driver is well worth the risk,IMHO. I would bet that lower stress would add a round win or two from time to time. On top of that it makes the whole day more enjoyable, and you may choose to race on a hot day when otherwise the heat might keep you home. Considering Montes' concern over electrical troubles, relays would help that situation in case of problems?
Re: Power windows?
[Re: 80arrow]
#2260614
02/27/17 05:57 PM
02/27/17 05:57 PM
Posts: 200 Colorado
Bob J
Colorado
If you have a set of power window mechanisms from a C body you can make it work in a B body if you change the arms. I did this in my 68 GTX and this may work in a A body.This bolts up like it's stock as they used the same basic setup and only changed the arms between them between models.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS 68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam 65 Chrysler 300 Convert. project 57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son 2003 Dodge Dakota R/T "DEAD"
