17" STEEL WHEELS FOR '89 D250? #2257905
02/22/17 09:36 PM
02/22/17 09:36 PM
n.c.
geo. Offline OP
geo.  Offline OP
n.c.
I've heard there are some chevy wheels that will fit.
Looking for a low buck way to put some 17" tires on my '89 D250.
Would like to hear from someone who's done it!
Re: 17" STEEL WHEELS FOR '89 D250? [Re: geo.] #2258309
02/23/17 08:21 PM
02/23/17 08:21 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Please forgive my ignorance; are those 5 lug or 8?
http://www.dieselplace.com/forum/76-spec...g-wheels-2.html
Re: 17" STEEL WHEELS FOR '89 D250? [Re: geo.] #2258403
02/23/17 11:36 PM
02/23/17 11:36 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
i know--i know---an 89 d250 is an 8 hole-----and those cool 17,s you see probably wont fit your truck because of an increase in the offset---so if you had a first gen cummins truck and you wanted those cool aluminum 16,s on a second gen truck you would find the front rim hits the tire rod end and the back rim wont fit over the rear drum----now on the even cooler 17,s you find the rear will fit and the front still is hitting the tierod---of coarse you can spend 100-200 on some cool wheel spacers....
Re: 17" STEEL WHEELS FOR '89 D250? [Re: savoy64] #2258814
02/24/17 05:11 PM
02/24/17 05:11 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Isn't there a ferd factory rim that will work on our 8 lug trucks?
Like a '92 or something?
I have mechanical Aptitude.
I can screw up anything.
Re: 17" STEEL WHEELS FOR '89 D250? [Re: bboogieart] #2258816
02/24/17 05:16 PM
02/24/17 05:16 PM
Pennsylvania
P
polaris400cc Offline
P
Pennsylvania
Only newer wheels that I know personally to actually fit older dodge d250 and 350 single rear wheel. Is the 94-02 2wd 16" chrome steel wheels and painted steel wheels and 94-03 dodge Ram 2500,3500 van steel wheels. Offset is obviously not the same as the originals, but fits even with 235-85x16 all around
Re: 17" STEEL WHEELS FOR '89 D250? [Re: geo.] #2258880
02/24/17 07:08 PM
02/24/17 07:08 PM
Pennsylvania
P
P
Pennsylvania
Operator error, I posted same thing twice
Re: 17" STEEL WHEELS FOR '89 D250? [Re: geo.] #2261372
02/28/17 11:39 PM
02/28/17 11:39 PM
n.c.
geo. Offline OP
geo.  Offline OP
n.c.
Thanks for all the help!
Anyone know the first year a 17" wheel was used on a 2500?
Re: 17" STEEL WHEELS FOR '89 D250? [Re: geo.] #2261516
03/01/17 06:52 AM
03/01/17 06:52 AM
North Carolina
jt1 Offline
jt1  Offline
North Carolina
2003.
