727 Identification help #2255708
02/18/17 10:19 PM
02/18/17 10:19 PM
New Lenox il.
CARMAN Offline OP
CARMAN  Offline OP
New Lenox il.
I picked up a trans the other day from an old friend of my dads. I need some help identifying it. Here are some pics of the numbers.
Re: 727 Identification help [Re: CARMAN] #2255728
02/18/17 10:38 PM
02/18/17 10:38 PM
until some one ans that knows numbers you might Google & see if a good site pops up
Re: 727 Identification help [Re: RapidRobert] #2255766
02/18/17 11:27 PM
02/18/17 11:27 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
67 440 and 68 383-4 and 440 early. wave
JB Rhinehart, Realist
A-Body's RULE!
Re: 727 Identification help [Re: Rhinodart] #2255777
02/18/17 11:41 PM
02/18/17 11:41 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
is there a partial VIN on it?
Re: 727 Identification help [Re: CARMAN] #2255781
02/18/17 11:51 PM
02/18/17 11:51 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
So close as I'm looking for a a 2801544
Re: 727 Identification help [Re: NANKET] #2255799
02/19/17 12:18 AM
02/19/17 12:18 AM
New Lenox il.
CARMAN Offline OP
CARMAN  Offline OP
New Lenox il.
The vin stamped on it is 8G149054. Actually I just found the vin number did not even see it until about 20 min ago I hate getting older. So with that number I am thinking 68 383 car just from the 8G .
Re: 727 Identification help [Re: CARMAN] #2255826
02/19/17 01:04 AM
02/19/17 01:04 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
it would be a (late-October '67) '68 B-body 383 4bbl/383HP/440HP non-Charger (probably Plymouth)
I have info on a car ~300 VINs later Road Runner 383HP 4-spd
Re: 727 Identification help [Re: 6bblgt] #2255829
02/19/17 01:09 AM
02/19/17 01:09 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
4225039 anyone have any ideas how the date & sequence numbers "work" on a transmission stamp like this one?
Re: 727 Identification help [Re: 6bblgt] #2255966
02/19/17 12:41 PM
02/19/17 12:41 PM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
I'm still waiting a response on the same question I posed a couple years ago.
:Project 2025, America's elite Mein Kampf
Re: 727 Identification help [Re: CARMAN] #2256123
02/19/17 04:51 PM
02/19/17 04:51 PM
Lewiston, ID.
screemindemon Offline
Lewiston, ID.
727s are date coded like small blocks, hemis and 4 speeds, using the 10,000 day calendar. There are 7 or 8 digits (there can be either) after the part number. First four are the assembly date, the rest the unit number. I think we are just missing a digit. Put a 2 before the 4 and we have a 68 assembly date, March 15 or so.
Re: 727 Identification help [Re: CARMAN] #2256132
02/19/17 05:02 PM
02/19/17 05:02 PM
Lewiston, ID.
Lewiston, ID.
Or, maybe the 4 is a mis-stamp. Change the 4 to a 2 and you have an assembly date that jives with the VIN date Dan gave.
Re: 727 Identification help [Re: 6bblgt] #2256152
02/19/17 05:32 PM
02/19/17 05:32 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The build date 4225 decodes to February 20, 1973 which is, obviously, not in sync with a '68 trans. Either it's a mis-stamp (2225) or it's a trans that was built at a later date as an over-the-counter replacement for a '68 trans.
Re: 727 Identification help [Re: screemindemon] #2256154
02/19/17 05:32 PM
02/19/17 05:32 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
years ago I proposed the "ASSUMED" missing 2 at the beginning of date
but as said above that makes this a March '68 trans in an October '67 car
2250 is late September '67, but can we consistently get there?
we need more examples of known original '67-'68 cars - VIN & part-number pad date
Re: 727 Identification help [Re: John_Kunkel] #2256156
02/19/17 05:34 PM
02/19/17 05:34 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
The build date 4225 decodes to February 20, 1973 which is, obviously, not in sync with a '68 trans. It's a trans that was built at a later date as an over-the-counter replacement for a '68 trans.
with a Feb. 67 tailshaft housing & what appears to be an original '68 partial VIN stamp? shruggy
Re: 727 Identification help [Re: CARMAN] #2256216
02/19/17 07:51 PM
02/19/17 07:51 PM
Lewiston, ID.
Lewiston, ID.
Re: 727 Identification help [Re: screemindemon] #2256220
02/19/17 07:54 PM
02/19/17 07:54 PM
New Lenox il.
CARMAN Offline OP
CARMAN  Offline OP
New Lenox il.
Is it possible that he put together some parts to build this trans.
He is getting up in age memory not what it used to be. He told me this was a hemi trans that's why he hung on to it all these years.It has a reverse manual valve body in it. This is the tag he had on it.
Re: 727 Identification help [Re: screemindemon] #2256221
02/19/17 07:55 PM
02/19/17 07:55 PM
Lewiston, ID.
Lewiston, ID.
Link above goes with VIN # XP29H9G189275. 2680 assembly date, November 27th, 1968 if I did my math right?
Re: 727 Identification help [Re: NANKET] #2256368
02/20/17 12:06 AM
02/20/17 12:06 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I have one.
I'm looking for a 3410671
