New Aluminum Big Block from BMP!!! #2254557
02/16/17 01:40 PM
02/16/17 01:40 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
It looks like BMP has released there Big Blocks in Hemi and Wedge. They did a lot of good things like dual bolt pattern trans and priority oiling. There customer service is great also. I order a rear cam plug for a block I had and Bill was very helpful even on a $20 part. When I build another motor they will be getting my business.
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: New Aluminum Big Block from BMP!!! [Re: 65 Hemi] #2254634
02/16/17 04:06 PM
02/16/17 04:06 PM
Cab_Burge Online work
Cab_Burge  Online Work
Haven't they been offering those blocks in aluminum for a long time? confused
Re: New Aluminum Big Block from BMP!!! [Re: 65 Hemi] #2254664
02/16/17 05:10 PM
02/16/17 05:10 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Yes they have Cab. They are making improvements though, according to Bill. Mine is holding up great after 4 rebuilds and 1050-1100 HP combos. Al has one that eclipses my stuff too.
Re: New Aluminum Big Block from BMP!!! [Re: Cab_Burge] #2254674
02/16/17 05:52 PM
02/16/17 05:52 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
When I talked with Bill a few months ago they were just starting production on them again. They stopped production for a while.
Doug
MOPAR or NO CAR!!!
Re: New Aluminum Big Block from BMP!!! [Re: 65 Hemi] #2254752
02/16/17 09:35 PM
02/16/17 09:35 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have used 5 of them. My current Predator is one as well but the block had some serious issue we had to address.
Re: New Aluminum Big Block from BMP!!! [Re: 65 Hemi] #2254756
02/16/17 09:47 PM
02/16/17 09:47 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Without pictures, they don't exist! whistling
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: New Aluminum Big Block from BMP!!! [Re: 65 Hemi] #2254795
02/16/17 11:21 PM
02/16/17 11:21 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Save your money and get a KB.
Re: New Aluminum Big Block from BMP!!! [Re: The Shadow] #2254805
02/16/17 11:29 PM
02/16/17 11:29 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
I have a KB block also but until I see production and the feed back on the new product/ castings I won't be buying a KB block.👍🏻
Doug
MOPAR or NO CAR!!!
Re: New Aluminum Big Block from BMP!!! [Re: Al_Alguire] #2254812
02/16/17 11:35 PM
02/16/17 11:35 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Al can you tell us the problems so we know what to look out for?
Doug
MOPAR or NO CAR!!!
Re: New Aluminum Big Block from BMP!!! [Re: 65 Hemi] #2254814
02/16/17 11:36 PM
02/16/17 11:36 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have a KB and Indy as well. My KB also needed some work to be useable not to mention an error on their part that cost me $$$ and I did not get what was ordered. The Indy block also had some minor things needed. IMO the KB is the best block and hopefully now with the new leadership you will be able to get one easily again. When that happens we will be getting one for sure.
As for a picture does this work...
Re: New Aluminum Big Block from BMP!!! [Re: 65 Hemi] #2254817
02/16/17 11:38 PM
02/16/17 11:38 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I think my last one was a "blem" block. It had some issues with the oil feed area of the block and the lifter angle was off. The others I have used there were no really big issues. This last one was and it was from a big name east coast Mopar engine shop.
Re: New Aluminum Big Block from BMP!!! [Re: 65 Hemi] #2255084
02/17/17 04:24 PM
02/17/17 04:24 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Nothing is new. Theyre not new products. Same castings from the same foundry as before. You'll just be able to get them from stock and that will be new.
BM makes a good restoration block but not for power.
Re: New Aluminum Big Block from BMP!!! [Re: The Shadow] #2255124
02/17/17 06:34 PM
02/17/17 06:34 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I don't recall Chrysler ever offering an aluminum 440 block in a production vehicle, or even a cross-bolted 440 block in any passenger car.
Re: New Aluminum Big Block from BMP!!! [Re: The Shadow] #2255129
02/17/17 06:49 PM
02/17/17 06:49 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
There is a comment from someone that doesn't know......
Re: New Aluminum Big Block from BMP!!! [Re: 65 Hemi] #2255155
02/17/17 07:46 PM
02/17/17 07:46 PM
Idaho
LaRoy Engines Offline
Idaho
I have one of the new BMP 440 blocks and it has been nothing short of a pain in the pahtut. And yes, some day I will document it all.
Re: New Aluminum Big Block from BMP!!! [Re: LaRoy Engines] #2255162
02/17/17 07:59 PM
02/17/17 07:59 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
OK, maybe they were a few problems after I got mine, but the KB's of late were needing lot's of extra work too. I'm sure with the new management they will be what they once were, but my world block has been flawless and on it's 5th rebuild as we speak. It never made less than 1000 HP.
Re: New Aluminum Big Block from BMP!!! [Re: camastomcat] #2255178
02/17/17 08:44 PM
02/17/17 08:44 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
And I bet its bouncing the mains out of it regularly.
When I wast talking restoration ,I meant restoration type power builds
Re: New Aluminum Big Block from BMP!!! [Re: 65 Hemi] #2255287
02/18/17 12:51 AM
02/18/17 12:51 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Wrong again. My second B1 original engine that made 1034@7200 lasted for 224 passes. The first Predator engine had 142 on it, and I wanted to see how everything looked, it was still in good shape and I could have kept running it. We'll see how it does this next time. I'm saying you can get a bad block from BMP, KB, HP Performance, or Indy. It's up to us to take it to the right people to right the wrongs. I'm sure KB will be a good option and I might buy one myself, but if BMP had a raised cam deal, I would buy one of those too.
Re: New Aluminum Big Block from BMP!!! [Re: 65 Hemi] #2255512
02/18/17 03:25 PM
02/18/17 03:25 PM
MD
JACK1440 Offline
JACK1440  Offline
MD
I fired mine for the first time the other night. So far so good. The only issue have been pushrods clearance and my issue with having to buy an extra tall lifter due to the lifter bushings.
Re: New Aluminum Big Block from BMP!!! [Re: LaRoy Engines] #2255554
02/18/17 05:30 PM
02/18/17 05:30 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
That is not good news... How responsive have they been?
