Clearance on Comp Cam Pro Magnum Rockers? #2253280
02/14/17 12:34 AM
02/14/17 12:34 AM
Cumberland, MD
Moparguy383 Offline OP
Cumberland, MD
I am using a set of Comp Cams Pro Magnum Rockers, mocking them up on Indy 440 EZ1 heads. I have no clearance between the rocker arms and the rocker stands. This is from Comp Cams instructions "The rocker arm dividers are stampings; tolerances are somewhat loose and fitting may be required to achieve proper clearance between the rocker arms. Minimum clearance should be approximately 0.030"
My question is how do I go about "fitting" them? Will a belt sander work or is this something that I have to take to my machinist?
TIA.
Re: Clearance on Comp Cam Pro Magnum Rockers? [Re: Moparguy383] #2253420
02/14/17 10:11 AM
02/14/17 10:11 AM
Locomotion Offline
Locomotion  Offline
I use to use a sandpaper roll or grinding bit on a drill or die grinder, or put one in a drill press and jig-up the rocker so I can have more control to slide it up to the roll/bit upside-down for consistency. Take off as little as possible in an arc to clear. Smooth/polish the area afterwards.
Obviously, grinding is not a good idea because it weakens the rocker. My permanent solution was to find a set of beehive springs with similar specs.
Because of the original "loose tolerances", you may have to go back and touch them up during installation.
Re: Clearance on Comp Cam Pro Magnum Rockers? [Re: Locomotion] #2253438
02/14/17 11:07 AM
02/14/17 11:07 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I think he is talking between rockers for side to side clearance.
Most will probably disagree, but if you think you can get it reasonably square with the axis, go for it.
Re: Clearance on Comp Cam Pro Magnum Rockers? [Re: Moparguy383] #2253481
02/14/17 12:37 PM
02/14/17 12:37 PM
Cumberland, MD
Cumberland, MD
Yes I'm referring to the side to side clearance.
Re: Clearance on Comp Cam Pro Magnum Rockers? [Re: Moparguy383] #2253499
02/14/17 01:20 PM
02/14/17 01:20 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Belt sander, fine grit and a steady hand is fine IME. Make sure valve/tip alignment is decent, you may need to alter the center spacers as well/instead. For small removal, a flat surface plate and sand paper works too. S/F....Ken M
Re: Clearance on Comp Cam Pro Magnum Rockers? [Re: Moparguy383] #2253529
02/14/17 02:18 PM
02/14/17 02:18 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I narrow up spacer between the rockers(I do it the lathe).
.015 side clearance per pair is plenty IMO.
Re: Clearance on Comp Cam Pro Magnum Rockers? [Re: Moparguy383] #2253535
02/14/17 02:27 PM
02/14/17 02:27 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
You shouldn't have to take anything from the rocker. Take it from the holdowns and the spacer. .030 is your friend.
Re: Clearance on Comp Cam Pro Magnum Rockers? [Re: Moparguy383] #2253541
02/14/17 02:36 PM
02/14/17 02:36 PM
Locomotion Offline
Locomotion  Offline
I gotta learn to read all the words instead of skimming! frown
Re: Clearance on Comp Cam Pro Magnum Rockers? [Re: fast68plymouth] #2253545
02/14/17 02:43 PM
02/14/17 02:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I agree.. I do them on the lathe or the mill.. .015 is
what I use
wave
Re: Clearance on Comp Cam Pro Magnum Rockers? [Re: Dave Hall] #2253547
02/14/17 02:52 PM
02/14/17 02:52 PM
So. Burlington, Vt.
So. Burlington, Vt.
On an Indy BB head, using the Comp rockers and hold downs, the rockers contact the stands, not the hold downs....... So narrowing the hold downs in this application doesn't buy you any added clearance.
