Re: Clearance on Comp Cam Pro Magnum Rockers?
[Re: Moparguy383]
#2253420
02/14/17 10:11 AM
02/14/17 10:11 AM
Posts: 5,894 Florida
Locomotion
I use to use a sandpaper roll or grinding bit on a drill or die grinder, or put one in a drill press and jig-up the rocker so I can have more control to slide it up to the roll/bit upside-down for consistency. Take off as little as possible in an arc to clear. Smooth/polish the area afterwards.
Obviously, grinding is not a good idea because it weakens the rocker. My permanent solution was to find a set of beehive springs with similar specs.
Because of the original "loose tolerances", you may have to go back and touch them up during installation.
[Re: Locomotion]
#2253438
02/14/17 11:07 AM
02/14/17 11:07 AM
Posts: 4,313 Prospect, PA
BSB67
Prospect, PA
Because of the original "loose tolerances", you may have to go back and touch them up during installation. I think he is talking between rockers for side to side clearance. Most will probably disagree, but if you think you can get it reasonably square with the axis, go for it.
[Re: Moparguy383]
#2253499
02/14/17 01:20 PM
02/14/17 01:20 PM
Posts: 490 IL
EchoSixMike
IL
Belt sander, fine grit and a steady hand is fine IME. Make sure valve/tip alignment is decent, you may need to alter the center spacers as well/instead. For small removal, a flat surface plate and sand paper works too. S/F....Ken M
[Re: Moparguy383]
#2253529
02/14/17 02:18 PM
02/14/17 02:18 PM
Posts: 14,496 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I narrow up spacer between the rockers(I do it the lathe).
.015 side clearance per pair is plenty IMO.
[Re: fast68plymouth]
#2253545
02/14/17 02:43 PM
02/14/17 02:43 PM
Posts: 52,972 Romeo MI
MR_P_BODY
.015 side clearance per pair is plenty IMO. I agree.. I do them on the lathe or the mill.. .015 is what I use
[Re: Dave Hall]
#2253547
02/14/17 02:52 PM
02/14/17 02:52 PM
fast68plymouth
So. Burlington, Vt.
You shouldn't have to take anything from the rocker. Take it from the holdowns and the spacer. .030 is your friend. On an Indy BB head, using the Comp rockers and hold downs, the rockers contact the stands, not the hold downs....... So narrowing the hold downs in this application doesn't buy you any added clearance.
