Page 3 of 3 1 2 3
Re: Measuring for pushrod length. [Re: ccdave] #2250174
02/09/17 03:42 AM
02/09/17 03:42 AM
Cab_Burge Online work
Cab_Burge  Online Work
Isn't Trend owned by Mahle, the German comglomerate company ? work shruggy
Re: Measuring for pushrod length. [Re: mopar dave] #2250278
02/09/17 01:04 PM
02/09/17 01:04 PM
warren, mich.
dwayne welder Offline
warren, mich.
Trend is owned by Bob Fox who also owns Diamond Pistons!!!!
Re: Measuring for pushrod length. [Re: dwayne welder] #2250297
02/09/17 01:37 PM
02/09/17 01:37 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
ok, do you know if they are the makers of the summit racing pushrods? just curious
Re: Measuring for pushrod length. [Re: mopar dave] #2250320
02/09/17 02:39 PM
02/09/17 02:39 PM
warren, mich.
warren, mich.
I have to stop by in the morning to pic some pushrods up and I'll ask them!
Re: Measuring for pushrod length. [Re: dwayne welder] #2250383
02/09/17 04:03 PM
02/09/17 04:03 PM
I was under the impression that Mahle had bought both from a former Diamond employee confused
Re: Measuring for pushrod length. [Re: mopar dave] #2250432
02/09/17 04:48 PM
02/09/17 04:48 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
The simple answer on why you have two different length pushrods is ANGLE. The intakes are offset and lean over more to get around the intake port. You lean it over, it has to be longer to cover same distance.
Many motors have 3 different lengths depending on port layout. One exhaust length, a left intake and a right intake length
ALL pushrods flex, nearly impossible to stop it. We have 9/16 intakes and 5/8 exhaust in our motor......they flex. Of course we have 500lbs on the seat and a cam with 1.200 lift
Re: Measuring for pushrod length. [Re: mopar dave] #2250739
02/10/17 12:01 AM
02/10/17 12:01 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Originally Posted By mopar dave
Not this time around. I was told summit racing pushrods are made by trend. Is that true. Never had Mantons and wanted to give them a try.
I like my Mantons, very nice pieces,,heard a lot of good about Trend also. up
Re: Measuring for pushrod length. [Re: mopar dave] #2250769
02/10/17 12:41 AM
02/10/17 12:41 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I don't think anybody makes bad ones. All made out of the same thing
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Measuring for pushrod length. [Re: B3422W5] #2250889
02/10/17 04:54 AM
02/10/17 04:54 AM
I really hope you don't believe that tsk
If you where nearer I would ask you to come over and look at some of the pushrods I have had fail shruggy I've bent them, broke them, burned them up and had them wear out shruggy
The good ones last a lot longer than the not so good ones, especially in racing up
Re: Measuring for pushrod length. [Re: mopar dave] #2250989
02/10/17 01:14 PM
02/10/17 01:14 PM
warren, mich.
warren, mich.
So to get back to the question does Trend sell to Summit ,Yes,but under a different Vender. To get more information on there pushrods go to there website or call them. They'll have the information your looking for.
Re: Measuring for pushrod length. [Re: mopar dave] #2251073
02/10/17 03:48 PM
02/10/17 03:48 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The material is less important that the fit & finish + quality control.
Heat treat can be done right, wrong, or not at all, and it's impossible to tell visually.
Not a place to save money. Why? because the difference between great and IDK isn't that big, and that's one less thing you ever have to worry about. Valve train problem? It's not the pushrods.
Some look really rough out of the box, makes you doubt that anyone at the plant gives a $*@#?}.
Examine the ends - if you see radial rings (instead of a smooth glossy surface), those are tiny hacksaw blades waiting to eat your rocker arm.
Examine the tubes where the ends insert - any sign of cracks, fretting, wrinkles, stretching, cut not exactly the same place all around? Danger.
Boffin Emeritus
Page 3 of 3 1 2 3
