School me on Dry Sump set ups. #2248949
02/07/17 03:22 AM
02/07/17 03:22 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
I'm thinking of stepping up to a dry sump oiling system. My car regularly pulls the front wheels & I've done a few repairs to the oil pan after the odd heavy touch down, but after my last repair I'm thinking we need to change the design. So what I want to know is, what kind of pump are you recommending, are Missile pumps any good, & some pics of your set up so I can design my upgrade ready for next season would be great.
Re: School me on Dry Sump set ups. [Re: rebel] #2248950
02/07/17 03:31 AM
02/07/17 03:31 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I'll be watching this..... my other W8 mill has the pump and pan, just not sure if that's a direction I should go.
Re: School me on Dry Sump set ups. [Re: J_BODY] #2249033
02/07/17 12:32 PM
02/07/17 12:32 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
This is what you want. http://www.daileyengineering.com Sexy
2011 Drag Pak Challenger
Re: School me on Dry Sump set ups. [Re: rickseeman] #2249065
02/07/17 01:34 PM
02/07/17 01:34 PM
Washington
madscientist Offline
Washington
Cha-chingalingading
Unless you are running Comp, Pro Stock, Pro Mod or a damn fast car that system is overkill.
Unless you have the money.
Re: School me on Dry Sump set ups. [Re: rebel] #2249073
02/07/17 01:49 PM
02/07/17 01:49 PM
South Central Pa
webemopes Offline
webemopes  Offline
South Central Pa
yes you are looking at 5 grand for that set up Peterson r4 pump is just as good 1700 for pump figure another 1000 for fittings and pan you are at a little over half the price of a dailys it is a sweet deal but if you aren`t a lottery winner I don`t know who can afford it lol
Re: School me on Dry Sump set ups. [Re: rebel] #2249078
02/07/17 01:54 PM
02/07/17 01:54 PM
AndyF Offline
AndyF  Offline
I've been running a dry sump on my big dyno mule for a few years now. Nothing too tricky about it, just a bunch of hoses and fittings. I use Peterson for the pump, drive and tank. You can use a stock type pan for a low dollar setup or buy a dry sump pan. I have a Kevko pan on the engine at the moment but I've used several Charlie pans also over the years.
Re: School me on Dry Sump set ups. [Re: AndyF] #2249115
02/07/17 02:58 PM
02/07/17 02:58 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
So while we are on dry sumps, gear, or roots style?
And how many stages, 5?, 3 in pan, 1 valley? work
Re: School me on Dry Sump set ups. [Re: rebel] #2249184
02/07/17 05:11 PM
02/07/17 05:11 PM
AndyF Offline
AndyF  Offline
I'm currently running a 5 stage R4 pump from Peterson. I have all four suction sections pulling from the pan.
Re: School me on Dry Sump set ups. [Re: rebel] #2249569
02/08/17 07:52 AM
02/08/17 07:52 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
whats the deal with running a vac on a dry sump? are the scavenge pumps also acting as a vac pump or that extra?
Re: School me on Dry Sump set ups. [Re: rebel] #2249641
02/08/17 12:51 PM
02/08/17 12:51 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
It is better/simpler to let the dry sump pull the vacuum. 5 stages, 4 suction in pan and 1 pressure.
Re: School me on Dry Sump set ups. [Re: rebel] #2249659
02/08/17 01:22 PM
02/08/17 01:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes.. the suction/scavenge lines will pull a
vac.... also remember when you buy a pump that
1 port is the pressure port, so a 3 port has
2 suctions lines and a pressure.. I ran a 4 port
on my R3 block.. 2 in the pan and 1 in the valley..
this was a dry sump block so the valley was sealed
and had to have a line up there(unless you drilled
return areas)
wave
Re: School me on Dry Sump set ups. [Re: MR_P_BODY] #2249661
02/08/17 01:27 PM
02/08/17 01:27 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
So pump was running approx 1/2? engine speed? How is proper pump speed calculated , or correctly verified once operational?
Re: School me on Dry Sump set ups. [Re: jcc] #2249673
02/08/17 01:44 PM
02/08/17 01:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes 50% of engine is fine.. just watch the
pressure of your system to verify... but 50%
seems to be the proper amount for pretty much
all of the engines... I borrowed a hand help
tach on the center of the pump shaft to check
mine... it was plenty close enough
wave
Re: School me on Dry Sump set ups. [Re: jcc] #2249805
02/08/17 05:39 PM
02/08/17 05:39 PM
AndyF Offline
AndyF  Offline
Rule of thumb for dry sump pumps is to run them at 57% of crank speed. I do not know where that rule comes from but you'll hear it from multiple vendors.
Peterson offers different pump widths so you can tailor the amount of volume from the pump. For example, if you are using the pump to build vacuum in the engine then you might want to spin it faster than 57% of crank speed. In that case you might want to use a low volume pump section so you aren't sending a bunch of oil thru the relief valve.
I use the narrowest possible pump section on my R4 pump and it still builds pressure with RPM. Watch the oil pressure on this dyno run and you can see what I'm saying. This is with the dry sump system and the oil pressure builds with RPM which tells you that the oil pump is big enough and/or the pump speed to too high. In my case I don't want to reduce the pump speed since I don't want to reduce pan vacuum and the oil pressure isn't too high so I leave it where it is.
https://www.youtube.com/watch?v=2zTAGAy081o
Re: School me on Dry Sump set ups. [Re: AndyF] #2250054
02/09/17 12:20 AM
02/09/17 12:20 AM
florida dade
cesar perez Offline
cesar perez  Offline
florida dade
andy how much does a system like yours cost
Re: School me on Dry Sump set ups. [Re: rebel] #2250071
02/09/17 12:34 AM
02/09/17 12:34 AM
AndyF Offline
AndyF  Offline
I don't really know since I didn't buy it as a package deal. The pump is probably around $1500 to $2000. The pan wasn't very much money, maybe $300 or so. The drive system costs a few hundred. I think I paid more than $1000 for the tank but you can get them much cheaper if you don't want all of the options. I added a heater and a sight gauge to mine as well as the pre-filter. I probably spent another $1500 on hoses and fittings. So maybe $5000 total if you start with nothing and buy it all brand new.
Re: School me on Dry Sump set ups. [Re: rebel] #2250085
02/09/17 12:46 AM
02/09/17 12:46 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
interesting reading.... I know pretty much nothing about dry sump. It just so happens that the "other" engine I picked up was pretty much complete less the tank and filtration. consider my stupid Q's nothing but "post bumps" at this point, I'm that far out of the loop. Considering it's a 9.0 deck block with no provision for standard oiling, and I have the pump and most of the plumbing and two pans, figured it would be "cost effective" to just use what I have.
I think P cleared one possibility. I have one smaller AN hose from the pump to the valley cover. "Assuming" this is for top end oil.
front line suction from front of pan, next two middle of pan, and back (smaller size) goes to valley cover
the two center plug caps (silver) were hand tight, the end, which has plugs on both in/out were tight. Also an allen plug opposite the front line from the pan.
So.... is a tank a tank? Any certain size for a drag only car?
Re: School me on Dry Sump set ups. [Re: rebel] #2250236
02/09/17 11:14 AM
02/09/17 11:14 AM
CJD AUTOMOTIVE Offline
I run a Dailey 5 stage on my R3. I have a gear pump section with lobe/rotor suction. It can pull well over 20" of vacuum, so you need an adjustable vacuum valve as well as a safety pressure valve. I too have 1 suction in the valley and 3 in the pan. Bill Dailey ask me specific questions on RPM, use, etc to determine the pump setup and speed.
I have a wet sump R3, but have my pressure feed split, one in the back, but also use the priority #1 main passage on the front of R3 blocks (on the front china rail).
I also have piston oilers installed on my block, mainly for turbo heat, but a side benefit of lubrication. The suction from the pump pulls the oil vapor from the crankcase, so the oilers help lubricate the walls.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: School me on Dry Sump set ups. [Re: rebel] #2250348
02/09/17 03:21 PM
02/09/17 03:21 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I run a 5 stage set up and this is my third. I can tell you the quality of the pump will determine the need for a vacuum pump in addition. With the Daily stuff there was no need for a vacuum pump. It pulled 20-22" of vacuum no problem. The Moroso and Peterson stuff I have used required a vacuum pump, they were 5-8" of vacuum with nothing else. Just got off the dyno with a stock car products one and it pulled 3" wit just the oil pump, all of these were 5 stage deals. From my experience Dailey stuff is HANDS down superior to the rest. You pay for that superiority to be sure, but IMO worth the money.
Getting the oil back in a BB Mopar is the biggest hurdle. One benefit is obviously less oil in the pan and reduced windage and if there is something catastrophic happens you have less oil in the pan to begin with. I have run both GOOD wet sump systems and a dry sump in a BB and frankly not sure there is any other huge benefit from the dry sump. If you run a Dailey pump you wont need a vacuum pump, anything else IMO you will need it. The expense can get up there for sure, but figure at least $4000 and up by the time you are done using something like a Moroso, or stock car products pump. The plumbing can get expensive for sure, one thing people don't take into account.
Re: School me on Dry Sump set ups. [Re: Al_Alguire] #2250371
02/09/17 03:50 PM
02/09/17 03:50 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
So when is a steel pressure section a good option vs alum?
