NHRA belly pan ideas #2237496
01/19/17 09:05 PM
01/19/17 09:05 PM
anywhere@ anytime
actionange Offline OP
anywhere@ anytime
Any pics of a NHRA legal under engine belly pan on a 66-67 B body?
Need ideas as I don't want to run a diaper due heat retention.
Im using a Charlie's deep aluminum oil pan with center link thru the pan and 2 inch Hooker headers.
Re: NHRA belly pan ideas [Re: actionange] #2237645
01/20/17 12:48 AM
01/20/17 12:48 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I wouldn't worry about the heat. Diapers don't fit that tight. Those headers make more heat than anything if they are not wrapped. Otherwise it's just your choice of an aluminum, fiberglass, carbon, steel pan with some "pigs" taped into the bottom that you could dzus fasten in for easy removal.
Re: NHRA belly pan ideas [Re: actionange] #2249261
02/07/17 07:37 PM
02/07/17 07:37 PM
TEXAS
Panty Dropper Offline
TEXAS
Go to a Chassis shop or even a Sheetmetal shop can build you a PAN... The minimum depth is 2" for NHRA tech to pass.. I run Top Sportsman and took my freaking diaper off and did this.. NHRA looked at it and gave me the thumbs up.. Also on your tech card you just write 2" Pan..
Hope this helps
