Go to a Chassis shop or even a Sheetmetal shop can build you a PAN... The minimum depth is 2" for NHRA tech to pass.. I run Top Sportsman and took my freaking diaper off and did this.. NHRA looked at it and gave me the thumbs up.. Also on your tech card you just write 2" Pan..
Hope this helps
